[Resolved] SEO by Yoast combination issue – page SEO section not saving
Home Support English Support [Resolved] SEO by Yoast combination issue – page SEO section not saving
This topic contains 2 replies, has 2 voices, and was last updated by  Lorincz 1 year, 7 months ago. The support staff assigned to this topic is Harshad.
July 19, 2013 at 9:49 pm #146823
Lorincz
When using together with the WordPress SEO by Yoast plugin, WPML Multilingual CMS 2.9 is apparently causing an issue: the page SEO section is not saving. Posts are OK. The bug appears even if there are no translations, disabling the WPML plugin solves it. See the thread over there:
http://wordpress.org/support/topic/page-seo-section-not-saving?replies=16#post-4436662
July 20, 2013 at 6:42 am #146838
Harshad
Forum moderator
Dear Lorincz,
Disable all other plugins, keep only SEO and WPML plugins enabled, also switch your theme to default twenty twelve.
See if in this case it works.
July 21, 2013 at 10:12 pm #147038
Lorincz
I did what you asked, saving worked fine. Then I switched back to my theme (BTW: Canvas by WooThemes), enabled all plugins, and the issue is still resolved. This is weird - can you explain, what happened in this workaround?
You must be logged in to reply to this topic.
