 Arian
I have a similar problem as the following topic: http://wpml.org/forums/topic/wpml-loads-wrong-mo-file-in-ajax-response/
I have tried many things but is still won't work. It just shows the default.
I use the following code:
<?php
require_once('../../../wp-load.php');
global $sitepress;
$sitepress->switch_lang('en', true);
$loaded = load_textdomain( 'blueprint', ABSPATH .'wp-content/languages/BlackBerry/'. get_locale() .'.mo');
// when i echo $sitepress->get_current_language() here, it displays 'en'
// when i echo get_locale() here, it displays 'en_US'
// the following file holds the translation fields
require_once('buildTicket.php');
I have tried the following:
- I have loaded the buildTicket.php file from within the template, then everything works fine, the file is perfectly translated in all languages i have. (So the .mo file is correct)
- I made some checkpoints in the load_txtdomain function (wp-includes/I10n.php) to check if the .mo file i am loading is the right one. The function starts loading the en_US.mo and it merges but after that, we still have the default language.
I have the problem in wp 3.3.2 with wpml 2.4.3. I have upgraded to wp 3.4 and wpml 2.5.1 but the problem is still there..
Can anyone tell me what the next step can be in the debugging process
 brooks
Dear Arian,
Is the ICL_LANGUAGE_CODE constant is changing ?
 Arian
Dear brooks,
A constant is designed to be constant, it stays the same in the execution time of the script.
 brooks
what does $loaded have? because it seems its not loading the mo file
 Arian
Dear brooks,
var_dump($loaded); says: bool(true)
So it should be loaded, but it is not..
I have tried to print the global that holds the values:
print_r($l10n['blueprint']);
But all the fields have the (default) 'de_DE' values, not the 'en_US' that i have requested.
 brooks
here http://codex.wordpress.org/Function_Reference/load_textdomain it says that:
If the domain already exists, the inclusion will fail. If the MO file is not readable, the inclusion will fail.
So maybe we need to unload_textdomain('blueprint');
 Arian
Hi Brooks,
I have tested the unload function and it seems to work!
I had examined the i10n.php file and i expcet it would overwrite the language but it doesn't, it only merges withoud overwrite.
