4
WooCommerce Multilingual is a very important project for us, today we are happy to announce that we have 4 WooCommerce Extensions to add to our compatibility list.
The extensions are YITH WooCommerce Multi Vendor, WooCommerce Ajax Layered Navigation, WooCommerce Composite Products, Product Alerts for WooCommerce
YITH WooCommerce Multi Vendor is a plugin developed to switch your website into a platform hosting more than one shop, like a multivendor marketplace.
Download YITH WooCommerce Multi Vendor
Ajax enabled layered nav widgets for your store.
Purchase WooCommerce Ajax Layered Navigation
Create complex, configurable product kits and let your customers build their own, personalized versions.
Purchase WooCommerce Composite Products
Give your customers the ability to signup and receive email notifications on any products they select.
Purchase Product Alerts for WooCommerce
4 Responses to “WooCommerce Compatibility – Multi Vendor, Ajax Layered Navigation, Composite Products, Product Alerts”
  1. WooCommerce is fully compatible with WPML through using WooCommerce Multilingual.
    As for WooCommerce Composite Products extension – I am sorry to say that there is a new issue related to newer WPML version, we have spotted that already and are working on a fix. I have also replied at the ticket with some more details.
