Last updated by Alejandro 6 months ago.
December 14, 2020 at 4:37 pm #7662417
Martin Mart
Have this portfolio entries on my site:
I used ACF to make it easy to add new content, but the translation does not work.
I have no clue how to manage this. I'm lost.
Please help.
Thank you very much.
December 16, 2020 at 4:01 pm #7679073
Alejandro
Hello!
Ok, there are a few things we need to make sure to meet:
1) Let's start by meeting WPML's minimum requirements:
Please add the following code in your wp-config.php file, right after the database information lines of code:
define('WP_MEMORY_LIMIT','256M');
1.1) Do a complete backup fo your site.
2) Please go to custom fields > All field groups and delete all the field groups from the translated languages (permanently)
3) Go to WPML > Settings > Post Type translation > Set "field groups" to "not translatable"
4) Now configure the translation preference of each field by editing the field groups.
As a rule of thumb, all structure fields (like repeaters, tabs, flexible content, etc) shoudl be set to copy and the content inside it could be set to translate if needed (translate = you need different values accross the languages. copy= you want to have the same values in the translations)
You can refer to this guide to know if you have configured everything correctly: https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
Then, when all that is done, make a small change to the page (using a native WordPress field like adding a character to the title) and then translate the page again.
Try it out and let me know how it goes.
The topic ‘[Closed] A smart way to translate portfolio entries with ACF and Co’ is closed to new replies.
