You are trying to translate a page where the ACF field is set to 'copy' value from the original language, but instead of copying, the field is translating the value in the ATE editor.
This behavior occurs because the Translation Memory is picking up the string and using it as a translation. To resolve this, you can manually undo the translation or add the string to the Glossary. For detailed steps on how to manage this, please refer to our guides on how WPML keeps track of your translations and how to create and manage glossary entries.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML support forum.
Last updated by 7 months, 2 weeks ago.
Assisted by: Carlos Rojas.
