Last updated by Lauren 1 year, 4 months ago.
October 12, 2018 at 9:11 pm #2813081
twentyZen
I am trying to: Use WPML for translation of an Avada based site.
Link to a page where the issue can be seen: (Avada Backend)
I expected to see: The complete list of Avada Fusion Builder Elements
Instead, I got: Only a few of the Avada Fution Builder Elements are shown, when WPML is activated.
It looks like a corrupted element interferes. How can I find the broken Fusion Builder Element that probably causes issues when WPML is activated?
October 15, 2018 at 2:58 pm #2818013
Lauren
It may be that some of the elements are missing from the configuration file. Please try going to the parent theme and looking for a file named wpml-config.xml. You can then copy the content there and go to WPML -> Settings -> Custom XML Configuration and paste the content there.
Then, you will need to update the original page with any small edit, and then when you edit the translation you should see all of the fields.
If the elements are not standard elements and coming from a plugin add on, you can add the shortcodes to WPML -> Settings -> Custom XML Configuration. Here is some additional information on language configuration files that may be helpful: https://wpml.org/documentation/support/language-configuration-files/
October 17, 2018 at 12:53 pm #2824625
twentyZen
Sorry I think I didn't explain the problem good enough.
Its individual(!) saved global Avada Elements, that are not shown to me as soon as WPML is activated. So these are elements that you save in Avada for later reuse. You can see the complete list of those elements typically, but as soon as WPML is running, the list is not showing everything.
October 17, 2018 at 5:59 pm #2825574
Lauren
Thanks for clarifying. Let's try this. Please be sure to make a full backup of your site and database. Then, go to WPML -> Support -> Troubleshooting. Look for 'Clean up' and click the following:
- Synchronize posts taxonomies
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Fix Terms count
- Fix post assignment for translations
After this, do all of the elements appear?
