Last updated by Carlos Rojas 2 years, 7 months ago.
April 10, 2019 at 9:29 pm #3581499
alexiaS-2
Tell us what you are trying to do? I want to add these new subdomains:
(For Hong Kong) hk.blog.tryandreview.com
(For Indonesia) id.blog.tryandreview.com
(For Malaysia) my.blog.tryandreview.com
(For Thailand) th.blog.tryandreview.com
(For Vietnam) vn.blog.tryandreview.com
(For Philippines) ph.blog.tryandreview.com
(For Brazil) br.blog.tryandreview.com
(For India) in.blog.tryandreview.com
(For New Zealand) anz.blog.tryandreview.com
Also want to make sure they are automatically redirected to these sites geographically.
Is there any documentation that you are following? No
Is there a similar example that we can see? You can follow the example of this website: hidden link
What is the link to your site? hidden link
April 11, 2019 at 2:14 pm #3588763
Carlos Rojas
1.- WPML has an option to automatically redirect users based on their browser language, you can read more about it in the following link: https://wpml.org/documentation/getting-started-guide/language-setup/automatic-redirect-based-on-browser-language/
Regarding the geographically redirection, this will need custom programming work which is beyond the scope of our support.
At this point I would suggest you consider contacting one of our certified partners from this link:
http://wpml.org/documentation/support/wpml-contractors/
Before doing so please have a look also here:
http://wpml.org/documentation/support/wpml-contractors/guidelines-for-people-looking-for-consulting-help/
You will get the custom assistance you need to get on with your project.
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
