Last updated by Lauren 1 year, 7 months ago.
September 29, 2018 at 11:19 am
arminA-5
I am trying to:Add
Link to a page where the issue can be seen:hidden link
I expected to see:Admin page with all menus correctly
Instead, I got:menus that does not fit the screen
October 1, 2018 at 5:13 pm #2778956
Lauren
I was not able to reproduce this issue in a test site, so I'd like to have you try a few things so we can try to isolate the issue. This is just to help me identify if it might be a conflict with another plugin or theme that is causing the problem.
** IMPORTANT ** Please backup a working copy of site files and database before continuing.
Update all WPML plugins & WordPress core.
Disable all plugins except WPML related and then temporarily change the theme to a default WordPress such as TwentySeventeen. With these settings, is the issue resolved?
Also, Please try increasing the WP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Add it above the line /* That's all, stop editing! Happy blogging. */
October 4, 2018 at 7:44 am #2786573
arminA-5
I ran health check on the website and go through troubleshooting steps and find out the issue is related to cornerstone. If I do disable cornerstone, I no longer experience the issue when I change the language to Persian.
October 4, 2018 at 1:58 pm #2787746
Lauren
Thanks for testing that for me. I installed the latest version of Cornerstone and I am not able to reproduce the issue. Please try updating to Cornerstone 3.2.5 and let me know if the issue persists. Thanks.
