This topic contains 31 replies, has 2 voices.
Last updated by Carlos Rojas 10 months, 1 week ago.
July 23, 2019 at 12:03 pm
tommaso rotundo
I created some custom fields in Italian. I duplicated the fields in the English version. Some fields works, others not.
I read the guides, but I can't solve.
In wpml string translation i've translate all.
Can i give you others specifics information in private?
July 23, 2019 at 12:54 pm #4266103
tommaso rotundo
Please, first to change anything on the website, alert me, i've to do another backup.
Many thanks
July 23, 2019 at 4:35 pm #4268187
Carlos Rojas
1.- Please describe the steps to reproduce the issue and what are the results you expect?
2.- Also, please update all outdated plugins and double check if the issue persists.
Kind regards,
Carlos
July 23, 2019 at 5:00 pm #4268293
tommaso rotundo
Hello,ok
click here (english page)
<em><u>hidden link</u></em>
in the result page there are some custom fields.
Country: Nicaragua (ok)
Strenght: Medio-forte (no, it's in italian)
Price 10-15 (ok)
Flavor Profile: Spezie, Cuoio, Tostato (no, it's in italian)
For example custom field Strenght.
In the php i've put this code (forza is Strenght):
<?php if (get_field('forza') != '') { ?><li><strong><?php _e('Forza:','movedo'); ?></strong> <?php the_field('forza'); ?></li>
<?php } else {}?>
I would like to see the translation in english for these fields (Strenght and Flavor profile). In Italian is all ok.
In wpml string translation i've translate all fields, look the image. The fields present in the search accordion (find cigars) are all translated.
Let me know if you need other informations.
Many thanks
July 24, 2019 at 7:09 am #4270945
tommaso rotundo
hello dear, have any news for me?
Many thanks
July 24, 2019 at 12:18 pm #4274335
Carlos Rojas
Please update all outdated plugins to their latest version. Outdated functionalities can cause can conflicts in the code.
Double check if the issue disappeared.
If the issue persists then I would like to ask you to change the code:
the_field('forza');
to:
_e(get_field('forza'));
Could you tell me the result of the steps above?
Carlos
Note: Please note that the flags are assigned to the opposite languages in the site.
July 24, 2019 at 1:08 pm #4274795
tommaso rotundo
Hello, i've put you code and finally i found in string translation all string to translate Domain "default"). But ther's a problem with field "flavor profile". I put your code, the result is
Flavor Profile:
Warning: md5() expects parameter 1 to be string, array given in /home/clients/c3955ff41c01ed3cced66c70405ebf8e/www.cigarslover.com/wp-content/plugins/wpml-string-translation/inc/functions.php on line 676
Array
This custom field is a checkbox
what can I do?
many thanks
July 24, 2019 at 1:16 pm #4274919
tommaso rotundo
i've a big problem, i've deactivated string translation plugin beacuse i've this error
July 24, 2019 at 1:23 pm #4275099
Carlos Rojas
Please roll back the changes in the code and let me know if the issue disappeared?
Carlos
July 24, 2019 at 1:27 pm #4275111
tommaso rotundo
I deleted the changes and reloaded the file. I activated string translation, but the problem is still there.
July 24, 2019 at 1:31 pm #4275187
Carlos Rojas
In this case I need to ask you to deactivate all plugins except WPML ones and activate a default WordPress theme. If the issue disappeared then start activating the theme and the plugins one by one until you see the issue re-appears.
Carlos
July 24, 2019 at 1:50 pm #4275353
tommaso rotundo
there is no other way to solve the problem? the website is online
July 24, 2019 at 2:30 pm #4275587
tommaso rotundo
I managed to restore a database backup.
I saw that when I modified the string "flavor profile", a record was created in the database table wtl_icl_strings (I attach image). I deleted this record and now it works.
So, can we to do now?
July 24, 2019 at 2:32 pm
July 24, 2019 at 2:45 pm #4275779
tommaso rotundo
Hi carlos,
ther's only a problem, the "upload" folder is over 12GB. Can i do it the same?
