Our next available supporter will start replying to tickets in about 3.16 hours from now. Thank you for your understanding.
Last updated by Carlos Rojas 9 months ago.
August 28, 2019 at 3:45 pm
shaneM-7
I am trying to:
Change Custom Fields Translation in Settings so that the AFC appear in the translator and frontend.
On my WP admin
I expected to see:
When I click save for it to remember my settings
Instead, I got:
"Data Saved" then the old settings remain
Desired end result:
All elements (mostly Included and Optional are the ones I am having issues with) to be delayed on the french version.
I have set up a test site for you to look about on, the link to the live site is:
August 29, 2019 at 9:52 am #4479557
Carlos Rojas
Please visit this link where you will find our official documentation about ACF: https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
Let me know if you need further assistance.
Kind regards,
Carlos
September 3, 2019 at 2:39 pm #4505485
shaneM-7
Hi Carlos,
Thank you for the response.
Unfortunately I have followed the steps in the documentation and still getting 'Error: data not saved' when modifying the repeater field "_modules" to copy. (As suggested in the guide).
Do you have any idea what is causing this?
Kind regards,
Tom
September 3, 2019 at 7:09 pm #4507041
Carlos Rojas
Hi Tom,
Thank you for your feedback.
I can't give you an answer with the information I have right now. That's why I would like to ask you to activate the debug mode by following the steps described in this link: https://codex.wordpress.org/Debugging_in_WordPress and let me know if there is any error message in the debug.log file after reproducing the issue.
Carlos
