Last updated by Carlos Rojas 10 months, 3 weeks ago.
June 26, 2019 at 10:18 am #4091389
francisJ
I am working in woo commerce project.I have a pop up section to add the product to the cart section.As given in the image uploaded when the currency switcher is in dollor(USD) and while adding a product to the cart the product is updating in the cart in default currency(AED).
Below given is the link hidden link
June 26, 2019 at 1:50 pm #4092915
Carlos Rojas
I would like to ask you to follow this steps:
- Create a full backup of the site before making any change.
- Update all outdated plugins and themes, specially WPML plugins. Outdated functionalities can cause conflicts in the code.
- Flush any cache memory that might appear.
If the issue persists then:
- Deactivate all the plugins that are not related to WPML.
- Go to WPML -> Languages -> Activate the Ajax cookie.- > Save the changes.
- Switch for a moment to a WordPress default theme like Twenty Seventeen or Woocommerce Storefront theme.
- If the issue is gone, activate one by one to see with which one there is an interaction issue.
Could you tell me the result of this steps?
Kind regards,
Carlos
June 27, 2019 at 1:11 pm #4100161
francisJ
I have checked all the methods what you have written.But no change in result.
June 27, 2019 at 1:18 pm #4100317
Carlos Rojas
In order to isolate the cause of the issue I have created a test site with a fresh new WordPress install, WPML, Woocommerce and WCML plugins.
I kindly ask you to finish the setup of Woocommerce and Woocommerce Multilingual. Also, please add the necessary theme, plugins and/or information to reproduce the issue.
You can access the test site using this link: hidden link
Carlos
June 28, 2019 at 9:10 am #4105823
francisJ
Hi, i have implemented the plugins and themes.Please find the below screenshot
July 1, 2019 at 6:52 am #4115891
Carlos Rojas
I was able to reproduce the issue in the test site, however I updated Understrap to it latest versión and I can't see the Ajax add to cart functionality any more. Could you roll-back the Understrap update? Or let me know how to activate the Ajax add to cart in the new version of the theme?
Carlos
July 5, 2019 at 4:50 am #4147469
francisJ
Dear Carlos,
Sorry for the late reply.i have done the roll-back of Understrap theme.Please see the below link for the Product Page.
Can you Please look into it and let us know.
Regards
Akhil
July 5, 2019 at 10:18 am #4150137
Carlos Rojas
Hi Akhil,
I have escalated this ticket to our compatibility team. Our compatibility specialists will take a deeper look at this issue and will try to find a solution.
I will get back to you as soon as I have an answer.
Carlos
July 8, 2019 at 4:42 am #4159029
francisJ
Dear Carlos,
Thank you for your response. Please let us know when a suitable solution is found for this issue.
Regards
Akhil
July 8, 2019 at 2:12 pm #4163347
Carlos Rojas
Hi Akhil,
Yes, I will keep you updated of the evolution of this ticket.
Thank you very much for your understanding!
Carlos
July 11, 2019 at 10:57 am #4188879
Carlos Rojas
Hi Akhil,
Can you please describe how to enable the mini cart feature in the latest version of the theme? Is the issue still there?
Also, could you provide contact information of the theme's authors?
Carlos
July 11, 2019 at 12:19 pm #4189643
francisJ
Hi Carlos,
We have customised the theme to provide the mini cart feature on the header section.Updating the theme might cause the loss of custom theme.
I am attaching the custom code what we had done.
add_filter('woocommerce_add_to_cart_fragments','woocommerce_header_add_to_cart_fragment');
function woocommerce_header_add_to_cart_fragment($fragments) {
    global $woocommerce;
    ob_start();
    <a class="cart-customlocation" href="<?php echo wc_get_cart_url(); ?>" title="<?php _e('View your shopping cart'); ?>"><img src="<?php bloginfo('template_url'); ?>/img/bag-ico.png" alt=""> <span><?php echo $woocommerce->cart->get_cart_contents_count(); ?> <span>(<?php echo $woocommerce->cart->get_cart_total(); ?>)</span></span></a>
    <?php
    $fragments['a.cart-customlocation'] = ob_get_clean();
    return $fragments;
July 11, 2019 at 1:03 pm #4189973
Carlos Rojas
Hi Akhil,
Thank you for your message, I just updated our compatibility specialists.
Carlos
July 11, 2019 at 8:04 pm #4193017
Carlos Rojas
Hi Akhil,
Our compatibility specialists don't see anything obvious and they can't debug custom code as it falls outside of our scope as a support service.
At this point I can recommend you to contact one of our certified partners in this link: https://wpml.org/contractors/
Carlos
