Last updated by Lucas Vidal de Andrade 1 year, 10 months ago.
November 9, 2023 at 1:40 pm
romainO-2
Placeholder text translation doesn't appear on the Front End, only on the Back End. It's for the specific placeholder text of the search field from Ajax Search Pro Plugin.
November 9, 2023 at 4:25 pm #14769959
WPML Supporter since 11/2023
I'll create a local copy of your website to analyze further your issue regarding the placeholder text. If you agree, please confirm that I can create the local copy to reproduce and investigate the error. Since I already have access to your website, I'll export it using All In One WP Migration 🙂
November 10, 2023 at 7:46 am #14772901
romainO-2
Hello
Yes you can !
November 10, 2023 at 12:38 pm #14776493
Thank you. I'll investigate the issue and get back to you as soon as I have feedback.
Lucas Vidal.
November 14, 2023 at 10:09 am #14796087
after copying your site to a local environment, I didn't have the issue. That means that the problem is being caused due to some server configuration of your website. I advise you clear and deactivate any kind of Cache you have, including the server Cache (you can usually do that by talking to your hosting provider). I hope that helps you 🙂
Have a wonderful day,
Lucas Vidal
