Applying translated images to custom posts build with Elementor Imaginam blocks does not show the translated images.
The issue is coming from
Imaginem Blocks
plugin.
To fix Elementor custom plugins we need some details from it's authors.
Please let your plugin author regarding this and ask him to check this: https://wpml.org/documentation/plugins-compatibility/elementor/how-to-add-wpml-support-to-custom-elementor-widgets/
If the author is willing to implementing this and if he needs any thing regarding this he can check our go-global program and we will gladly help him 🙂
https://wpml.org/documentation/theme-compatibility/go-global-program/
We really regret to inform you that we are unable to provide any workaround for this for now till the author contacts us.
Relevant Documentation:
Last updated by patrickF-31 1 year ago.
May 16, 2019 at 7:11 am #3822407
patrickF-31
I have translated a few posts developed with Elementor using the Translation Editor. Also translated image names and caption with Media Translation. Now how can I have the translated post refer to translated images embedded in image galleries within Elementor?
May 16, 2019 at 7:28 am #3822609
Riffaz
I am explaining you the steps again:
please
1. go to hidden link
2. install your theme
3. istall the elementor
4. configure the WPML as you have it on your site. at the last step just click next (site key)
5. upload and translate only one image
6. create only one page with element you are using and set the image.
7. recreate the issue.
8. let us know how to check this and how to recreate this issue.
9. explain the step 8 with screenshots and URLs for better understanding.
Let me know.
Riffaz.
May 16, 2019 at 8:40 am #3823313
patrickF-31
Hi Riffaz,
I have completed the steps above and I'm able to replicate the issue.
1) I create one page and publish it.
(I tried creating a custom portfolio post but it doesn't work in your environment, when I try to view the post even before editing in Elementor I get a 404 error message).
Anyway I face the same issue with a standard page.
2) I edit the page in Elementor, add one block of text and then a custom widget called Thumbnails Grid.
3) I upload one image in the gallery for this widget, set the Title in English and save.
4) I translate the image title in French using Media Translation.
5) I translate the page in French using Translation Editor and save.
6) I view the page in French. Text has been translated but if you hover over the single image, you will see that the image title which is displayed is still in English.
On my production site, I went one extra step: opened the translated page in Elementor then saved. After that the translated image title is displayed while hovering. I did not do it in your sandbox environment so that you can see the issue.
May 16, 2019 at 9:49 am #3824283
Riffaz
Thank you for this.
I escalated this to our compatible team.
Please be patient till we get back to you.
May 22, 2019 at 10:49 am #3864489
Riffaz
Thank your for your patient.
Imaginem Blocks
plugin.
Riffaz.
May 27, 2019 at 10:07 am #3895737
patrickF-31
