This topic contains 13 replies, has 3 voices.
Last updated by Raja Mohammed 1 year ago.
January 29, 2019 at 12:31 pm #3139690
Gokhan Baydemir
​Hi,
In Arabic and Persian language, the writing direction of the telephone number should not change. I showed the wrong and correct writing in the photographs. What can we do for this?
Thanks...​
January 29, 2019 at 2:01 pm #3139954
Noman
Thank you for contacting WPML Support. You can fix this issue by adding following CSS in your theme’s or child theme style.css file OR Custom CSS section of the theme:
html:dir(rtl) .top-bar-phone span {
    direction: ltr;
    display: inline-block;
html:dir(rtl) .widget-contact ul li {
    direction: ltr;
html:dir(rtl) .widget-contact ul li i {
    direction: rtl;
    display: block;
    float: right;
html:dir(rtl) .profile-contact li a {
    direction: ltr;
And it will look as in attached screenshot.
Thank you
January 29, 2019 at 2:53 pm #3140295
Gokhan Baydemir
Firstly, thank you. But it didn't work where I put the code. Theme panel, style file etc. It didn't happen. Where am I supposed to put the code?
Thanks...
January 30, 2019 at 8:27 am #3142614
Noman
Could you please try to put that code in WPML >> Languages >> Language switcher options > Additional CSS section and let me know how it goes?
If still issue persists, please provide temporary access (WP-Admin and FTP Login info) to your site (preferably staging site), so that I can look into your setup and debug the issue.
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
Thank you
January 30, 2019 at 1:10 pm #3143981
Noman
WP login info that you had provided is not working here. Could you please provide me working login please. I have enabled private input box for your next reply.
Thank you
January 30, 2019 at 2:14 pm #3144257
Noman
Thanks for login details. I have replaced ‘html:dir(rtl)’ selector with ‘html[dir=rtl]’ and now CSS is working fine. Could you please check and confirm?
Thank you
January 31, 2019 at 2:24 pm #3148270
Gokhan Baydemir
Thank you very much. But we missed a few places. I would appreciate it if you can fix them. I tried to do it myself, but there were shifts in the icons.
Thank you...
January 31, 2019 at 2:56 pm #3148425
Noman
Could you please provide me page links where this issue needs to be fixed.
Thank you
January 31, 2019 at 3:17 pm #3148530
Gokhan Baydemir
1) The lowest part agent information
2) Agent information when you click on the ad photo
January 31, 2019 at 4:47 pm #3148919
Noman
Thanks for pages links. I have fixed on both places and now it looks as in attached screenshot.
Thank you
January 31, 2019 at 5:50 pm #3149115
Gokhan Baydemir
there are problems on mobile. Thanks
February 3, 2019 at 10:19 am #3155182
Noman
You can fix mobile display issue by using below CSS:
@media(max-width:768px) {
.agent-media span {
    display: block;
Thank you
February 4, 2019 at 9:18 am #3156700
Gokhan Baydemir
hi,
thanks but I have trouble seeing the numbers on the desktop. There's still a problem in mobile.
February 5, 2019 at 7:33 am #3160584
Raja Mohammed
Noman is off today, I will be taking care of your issue. I hope that would be ok for you 🙂
I have fixed the style issue, Please verify it from your end.
Please note customization of these kinds is beyond our support capability we can only help with an issue related to WPML, The CSS issue is more of theme related. Please if you have any further issue with CSS kindly take it to the theme support.
I hope the issue is resolved. Let me know if you need further assistance.
Kind regards,
Raja
