Hello there,
So i have set up 2 lang and 2 domains (.com default and .ro parked) as parked, everything is ok on dashboard and on front, but i have this issue:
If i type domainA.com it will go to hidden link, but if i set domainB.ro it will redirect to hidden link; so if i want to access the 2nd website (parked one) directly i need to type full address which will be hidden link.
Similar issue i found here but without solution https://wpml.org/forums/topic/auto-redirect-problem-with-different-parked-domains-per-language/
Also like the user above the website is hosted on siteground, they told me this:
"I checked and noticed that in the dashboard under the WPML - Languages section, there is a Language URL format. By default the entry in there is hidden link and we cannot change it."
Just add this to htaccess
RewriteEngine On
RewriteCond %{HTTPS} off [OR]
RewriteCond %{HTTP_HOST} ^www\. [NC]
RewriteCond %{HTTP_HOST} ^(?:www\.)?(.+)$ [NC]
RewriteRule ^ hidden link{REQUEST_URI} [L,NE,R=301]
