Please run this test and let me know the results:
- Deactivate WCML for a moment
- Make a small edit in the Beaver Builder content on the original product and save the changes
- Retranslate the product
- Reactivate WCML
I'm glad to hear that the workaround solved the problem.
1.- The steps described in my previous message were only a workaround designed to let you translate the content; however, our specialists recommend using the Advanced Translation Editor instead of the Classic Translation Editor to translate the content, especially with Beaver Builder.
2.- Regarding the language switcher problem: can you share a URL where the issue can be seen? This will allow me to check if there is any JS conflict stopping the switcher from working correctly.
Note: Please make sure the translated products are published, and the secondary languages are not hidden.
Please fix this plugin asap since the Advanced Translation Editor is no option for us for well known reasons. The products are published but the flag on the product page cannot be changed, in whatever language you are. The site is not yet publicly available. Thanks
D G
