Problem: Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Argument ID must be numeric and greater than 0.'
Solution: Upgrading the plugin to Latest version 3.6.1 solved the issue.
Relevant Documentation: https://wpml.org/errata/fatal-error-uncaught-exception-invalidargumentexception/
Last updated by ariefw 3 years, 1 month ago.
December 2, 2016 at 10:26 am #1149784
ariefw
just buy wpml 4 days ago, install WPML multilingual cms plugin into my live website, activate, basic setup indonesian(default)-english translation, activate footer language switcher, visit site, and blank homepage
so I decided try the plugin setup into a copy of my live website running in localhost instead of live ones. doing same setup step, but iam putting the language switcher into theme's header using shortcode, visit site, default homepage which is indonesia is normal (see attached screenshot), when switch into english only language switcher show up and the rest is blank with error (see attached screenshot) :
Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Argument ID must be numeric and greater than 0.' in /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/translations/class-wpml-translation-element.php:28 Stack trace: #0 /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/translations/class-wpml-term-element.php(19): WPML_Translation_Element->__construct(NULL, Object(SitePress), NULL) #1 /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/translations/class-wpml-menu-element.php(17): WPML_Term_Element->__construct(NULL, Object(SitePress), 'nav_menu', NULL) #2 /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/language-switcher/class-wpml-ls-settings.php(313): WPML_Menu_Element->__construct(NULL, Object(SitePress)) #3 /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/language-switcher/class- in /Applications/MAMP/htdocs/unissulamulti/wp-content/plugins/sitepress-multilingual-cms/classes/translations/class-wpml-translation-element.php on line 28
about the site :
1. using wordpress v4.0
2. using custom theme called tonjoo (we hire third party to develope it)
3. the plugin that active are : akismet, regenerate-thumbnails, baw-post-views-count, simple-subscribe, better-search-replace, single-post-template, breadcrumb-navxt sitepress-multilingual-cms, contact-form-7, toggles-shortcode-and-widget, fluid-responsive-slideshow, tonjoo-library, tonjoo-ultimate-post-list, json-api, types, json-rest-api-wp-api-categories-and-tags, ubermenu, m-wp-popup, wp-api-json-reader, media-tools, wp-sitemap-page
please help me how to make this works, thank you very much
December 2, 2016 at 12:27 pm #1149973
Ankit
Can you please apply this errata and check if this helps you?
Errata: https://wpml.org/errata/fatal-error-uncaught-exception-invalidargumentexception/
Also, this issue has been fixed in wpml version 3.6.1, so I would request you to kindly update wpml cms plugin to version 3.6.1
To receive automatic update of plugin, please refer : https://wpml.org/faq/install-wpml/#receiving-updates
To update wpml plugins manually, please refer: https://wpml.org/faq/install-wpml/#updating-manually
Please let me know if it helps.
Ankit
December 5, 2016 at 8:44 am #1151138
Shekhar Bhandari
Could you please let me know if the solution posted by Ankit helped you?
I look forward to your reply.
December 5, 2016 at 9:12 am #1151176
ariefw
Hi, Ankit, and also Shekhar,
I just update the plugin to 3.6.1 and the error message is gone, my homepage is appears like normal right now, but i guess its time to make another thread since my homepage news that handle by ultimate post list plugin shortcode (list sort by post category) is blank, although the post already translated
Thank you very much for your help
