This topic contains 18 replies, has 2 voices.
Last updated by rohanK 9 months, 4 weeks ago.
November 26, 2019 at 7:07 pm #5024565
Thank you very much for the clarification.
As I see that English is your default language and revised your posts and I can see that the "Relative posts" section is appearing on some post pages and on other not.
My question is: How has this widget been created? I do not find it in Appearance -> Widgets, neither on the WPBakery Page Builder.
Kind regards
November 26, 2019 at 7:40 pm #5024905
rohanK
Sorry I did not get it. I guess it is in the theme template, but not sure.
Let me know if you need other info,
Kind regards,
Sophie
November 26, 2019 at 11:56 pm #5025563
In fact, this is true. I now checked on our prior installed test-site. This section seems to come from the theme as seen here:
I was only wondered why it appears on some of your English posts and on others not.
Even if I disable all WPML plugins this section does not appear on many posts, but on those where it appears, it does also appears on all language URLs (duplicated posts).
Example:
"Succeed in your Skype interview" does not include related posts on default English language. The same I see on "Do’s and don’ts after a job interview", and "The most common questions asked in an interview" and others.
Actually only the two posts assigned to the CV advise category do show the related posts, and they show them on all language URLs, as mentioned already.
As it behaves the same if WPML is disabled, I would suggest you contact the theme support for further assistance about this issue.
Anyhow, in case there are appearing any further issues when it will come to translate the content I will be delighted to assist you again, just for now there is nothing we could do from our side, as the issue seems to be linked to another plugin.
Try deactivating your plugins and test the theme alone. If the issue persists, reactivate plugins one by one to indicate the one that is triggering the issue and contact the respective support team.
Kind regards
November 27, 2019 at 10:45 am #5028123
rohanK
Hello Andreas,
Oh okay I see, sorry about that. I actually get what was wrong by rechecking the issue and it was related to theme settings.
Sorry for the struggle,
I wish you vary good day,
Kind regards,
Sophie
