Last updated by michaelM-101 1 year, 8 months ago.
Assigned support staff: Otto.
September 19, 2017 at 11:28 pm #1377161
michaelM-101
I am trying to: Add products to cart on english language
I expected to see: Products added to cart
Instead, I got: Message that product is added to cart but when viewing cart it says empty cart.
PS. It works to add products to cart and also proceed to checkout on Swedish language. I have created products for swedish and english language.
September 20, 2017 at 7:41 am #1377396
Otto
Thank you for contacting the WPML support!
Please try the following:
Go to WPML > Languages > Language filtering for AJAX operations and check the option.
If that does not help, is it possible for you to check for compatibility issues doing the following test:
-Backup your site first
-Deactivate all the plugins that are not related to WPML, keep also WooCommerce and WooCommerce Multilingual
-Switch for a moment to a WordPress default theme like Twenty Fourteen.
-If the issue is gone, activate one by one to see with which one there is an interaction issue
If the issue persists, it would be good if you can provide me the WordPress debug.log.
To enable it, open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
define('WP_DEBUG', true);
In this case the errors will be saved to a debug.log log file inside the /wp-content/directory.
If you can paste your debug.log to pastebin.com and provide me that link it would be great! (This is the cleanest way, because sometimes the logs are long and create a complete mess in discussion).
Kind Regards,
Otto
September 20, 2017 at 1:54 pm #1377930
michaelM-101
I deactivated all plugins one by one and tested to add products to cart, this plugin caused the problem.
- WPML Media
Question is do I really need this? When installing WooCommerce multilingual it says that is needs that extra plugin but seriously, I haven't seen what function it has? If its not a necessary plugin then don't tell the user to install it because this caused a serious problem.
