Related documentation:
This topic contains 24 replies, has 2 voices.
Last updated by rufusB 2 years, 1 month ago.
November 3, 2018 at 6:05 pm #2874008 | |
rufusB |
I am trying to: update exchange rates automatically and edit default currency Instead, I got: The exchange rates were stuck in 2017 according to the manual updater and are still stick in June 2018 according to the auto updater. I've tried using fixerio and currencylayer APIs but neither will work. I was able to update manually. |
November 5, 2018 at 9:06 pm #2878468 | |
Itamar Supporter
Languages: English (English ) Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+02:00) |
Hi. Are you using the free or paid API from fixerio or currencylayer? Regards, |
November 5, 2018 at 9:16 pm #2878491 | |
rufusB |
Hi Itamar, |
November 5, 2018 at 9:25 pm #2878509 | |
Itamar Supporter
OK, thanks for the extra information. I suspect that there is a collision with the theme or another plugin. Regards, |
November 7, 2018 at 12:32 pm #2885204 | |
rufusB |
Hi Itamar, I tested in twenty seventeen as you suggested, including with all but WPML and woocommerce plugins deactivated and caches flushed. Unfortunately the problems persist. |
November 7, 2018 at 9:26 pm #2887145 | |
Itamar Supporter
Hi and thanks for trying my suggestions. If the minimum environment procedure did not point to the problematic plugin or theme, please do the following: Change it to: define('WP_DEBUG', true); // Enable Debug logging to the /wp-content/debug.log file define('WP_DEBUG_LOG', true); // Disable display of errors and warnings which is recommened on a live site. define('WP_DEBUG_DISPLAY', false); @ini_set('display_errors',0); define( 'WP_DEBUG_LOG', true ); Then please press the 'Update manually now' button and check the debug.log In this case, the log will be saved to a debug.log log file inside the /wp-content/directory. Please, could you provide me the additional Info? Thanks, |
November 7, 2018 at 10:15 pm #2887188 | |
rufusB |
Hi, that didn't go so well. I tried twice and it crashed the site, giving a syntax error message. I was unable to undo the edit and had to replace the entire file. Can I upload the file for you to take a look at? |
November 8, 2018 at 4:50 pm #2890194 | |
Itamar Supporter
Hi and sorry that that didn't go well. Do you mean that you want to send me the wp-config.php file? If you need further help with this, please share the access details to your site with me. Privacy and Security Policy We have strict policies regarding privacy and access to your information. Please see: **IMPORTANT** - - Please make a backup of site files and database before providing us access. -- Thanks, |
November 8, 2018 at 8:34 pm #2890932 | |
Itamar Supporter
Hi and thanks for the access details. I'll check the issue and be able to reply on Sunday. Thank you for your patience. |
November 11, 2018 at 10:33 am #2896445 | |
Itamar Supporter
Hi and thanks for the access details. I'm glad that you can now manually update the exchange rate from GPD to USD. About the following issues. Please let me know if it clear now? About the 'can't change default currency' issue. I look forward to your reply! Itamar. |
November 11, 2018 at 2:32 pm #2896545 | |
rufusB |
Hi Itamar, thanks for that, which clears up the automatic exchange rate update part of the problem. However, I was also referring to my attempts to update the Currencies interface ABOVE Automatic Exchange Rates. As you will know, I have three currencies in use, with two options for each language (I was unable to make all three currencies available in both languages, see below). After temporarily changing default currency to Euros to test updating exchange rates manually, which worked, I found when I reverted to GBP as base currency that euros has disappeared completely and, although listed as default currency, GBP could not be checked and saved in the English language switcher, resulting in all prices in USD. See attached. The settings in this interface are only intermittently editable, I have never understood why one day they save, the next they don't. As today they don't save, I had to restore a backup to regain Euros and GBP. This is the outstanding problem. Cheers, Rufus |
November 12, 2018 at 12:48 pm #2898499 | |
Itamar Supporter
Hi, Rufus. I'm glad that the Automatic Exchange Rates issue is solved now. Are you still having issues saving changes in the multi-currency section? Thanks, |
November 12, 2018 at 1:05 pm #2898562 | |
rufusB |
Hi Itamar, yes, as above, I had to install a backup to regain the original settings as I was unable to edit them. In doing so, I have lost the settings from the Automatic Exchange Rates manual update so until both issues are resolved, none are resolved I'm afraid. |
November 13, 2018 at 10:12 pm #2904563 | |
Itamar Supporter
Hi. I've managed to install your site on my local server (it wasn't easy). On my local server, I can update the multi-currency settings. So I still need to investigate this issue. But meanwhile, I've noticed that you are also using the WooCommerce Multi Currency plugin. Thanks, |
November 13, 2018 at 10:47 pm #2904590 | |
rufusB |
Hi, I use that plugin on and off as sometimes it seems to make the manual update of the Currency interface editable. Today it didn't. Given that i've tried many permutations with and without it, it's doubtful that it has any bearing on the issue. |
