Last updated by Carlos Rojas 1 year, 8 months ago.
September 26, 2018 at 6:42 am
alexandrosA-3
I am trying to: switch language and check the cart / or fill the cart in a secondary language (not English)
I expected to see: the cart contents carry over when changing language. Or cart contents increase when using a secondary language.
Instead, I got: When I tried to switch language and check the cart / or fill the cart in a secondary language (not English) my cart was emptied. The cart works fine in english but is getting reset if I use any other language.
September 27, 2018 at 12:01 am #2768866
Carlos Rojas
1.- I would like to ask you to follow this steps:
- Create a full backup of the site.
- Update all outdated plugins.
- Flush all cache memory,
- Finish the translation of the products.
- Go to Woocommerce -> Woocommerce Multilingual -> Settings tab -> Troubleshooting link (bottom right) -> Sync all products.
Could you tell me if the issue persists?
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
September 27, 2018 at 2:21 pm #2770812
alexandrosA-3
However these steps did not fix the issue and it continues to appear. I see that when I use a signed up user that issue does not appear. It only appears when a user is not signed up and is browsing the site as a guest. Do you have another suggestion?
September 27, 2018 at 3:18 pm #2771019
alexandrosA-3
Further testing proved that on my testing "staging" site, which is an exact replica of the original, the issue does not appear. The cart works fine between translations there.
Admin credentials are the same there. You may use it to troubleshoot if you may. Thank you.
September 27, 2018 at 8:02 pm #2771715
Carlos Rojas
Before I log in the site I kindly ask you to flush all cache memory, specially WPEngine cache memory and double check if the issue persists.
Carlos
September 28, 2018 at 7:20 am #2772736
alexandrosA-3
I cleared the cache and the issue persists.
September 28, 2018 at 2:03 pm #2774147
Carlos Rojas
- Change the slug of the cart page in Greek to a plain text like 'cart-greek' -> Save the changes.
- Go to Settings -> Permalinks -> Re-save the permalink structure.
- Flush the cache memory.
Rgards,
Carlos
October 3, 2018 at 12:18 pm #2784470
alexandrosA-3
It seems that the issue now is at last resolved.
I had the product translation all finished so I did not do that step
I changed the slug of the cart page to use only latin letters instead of greek letters (maybe that fixed it? I thought I could use any UTF-8 char for a url). Now the cart page in english is: /cart and in greek it's /el/cart
I did the same for the checkout page.
I resaved the settings->permalinks and flushed the cache
The cart now works just fine in greek.
Does that mean that I cannot use full UTF-8 urls for WPML?
October 3, 2018 at 6:06 pm #2785445
Carlos Rojas
There is a known issues with transients and characters that aren't latin in the slugs of the Woocommerce pages. Our developers are working on a solution that should be included in the next release of the plugin.
Carlos
