Last updated by Maciej 6 years ago.
Assigned support staff: Maciej.
August 27, 2015 at 10:54 am #691118
Jelle
I am trying to: Change the default language from Dutch to English. This website will be a .com instead of an .nl. There for I want the default language to be English. When I started building this website (on a test environment) I did not realize that the default website should be English instead of Dutch. Therefore I want to change it before we go live.
URL of (my) website where problem appears: hidden link
I expected to see: The website as an English website.
So: hidden link (This should be the English version)
and: hidden link (this should be the Dutch version)
Instead, I got: Strange styling and It automaticly goes to the blog page and problems with the perma links. In conclusion, it is not working rightnow
August 28, 2015 at 6:48 am #691839
Maciej
Thank you for reporting your issue.
May I kindly ask you to update your WPML plugins to the latest versions?
https://wpml.org/2015/06/wpml-3-2-released/
You can download it from the download section of your wpml.org account.
Remember to backup your database and website first before you proceed. You can use a plugin for this if you like. I often use the Duplicator plugin for this purpose.
See: http://wordpress.org/plugins/duplicator/
Please let me know if this solves your issue.
Maciej
The topic ‘[Closed] Change default language from Dutch to English gives problems’ is closed to new replies.
