Last updated by Oriana 8 years, 11 months ago.
March 25, 2011 at 2:24 pm #24721
Amir
If you're running into compatibility problems with other plugins or themes, the best way to fix them is to get the authors of those plugins / themes involved.
We work together with any author who's prepared to work with us.
Contact the other author and let us know. We'll create free accounts for them so that they can download WPML and participate in this forum.
We'll do everything that it takes to get WPML to work together with other plugins and themes. All we need is cooperation from the other side as well.
April 4, 2011 at 9:56 am #24723
Alexander
Is there any SEO plugin (that has option to set Title and Meta Description tags) compatible with WPML? For instance All in One SEO and SEO Ultimate doesn't work.
April 4, 2011 at 12:46 pm #24724
Amir
This plugin works very well with WPML:
http://wordpress.org/extend/plugins/wordpress-seo/
April 16, 2011 at 9:15 pm #24725
Oriana
Hi Amir,
Would you be able to tell me whether WPML is compatible with the "improved include page" plugin (http://wordpress.org/extend/plugins/improved-include-page/)? It's an handy plugin as it allows to include the content of a static page in a template (e.g. in the sidebar), but it works with a function that takes the id of the page as parameter. Therefore the translated version of the static page you're calling with the function doesn't show up when you switch language, because of course it has a different ID.
Should I ask the plugin's author? Can you think about any way around this problem?
Thanks a mill!
The topic ‘[Closed] Compatibility problems with other plugins and themes’ is closed to new replies.
