Problem: Composite products disappear
Solution: To solve the problem the client decided to use the Translation Editor. To do this:
- Click on the WooCommerce > WooCommerce Multilingual > Settings - On the "Product Translation Interface", select "WPML Translation Editor" option - Click on the "Save changes" button
Last updated by tobiasL-11 3 years, 10 months ago.
July 20, 2017 at 12:35 pm #1323634
tobiasL-11
I am trying to:
Publish edit the english translation of my composite product
Link to my site:
tapemuzik.de
I expected to see:
A working screen with english translation.
Instead, I got:
It worked fine, but then I made a change in the composite product. It now tells me to add atleast one component and wpml tells me that these parts are automatically copied from the german version. so i cant edit it :(.
I would like to grant you wp access, but I cant without granting ftp access wich is not an option sadly.
July 20, 2017 at 1:49 pm #1323712
Bruno
Thank you for contacting us.
If you save the translation (access the translation page and save, without editing anything on the translation page), does the problem persist?
Also, I can not access the secondary language, as it looks like this is hidden. Maybe you can create a copy of your site with Duplicator plugin and send it to me so I can test it in my test environment if the above steps do not work.
If so, let me know so that I activate the private response.
July 28, 2017 at 9:48 am #1329542
tobiasL-11
The duplicator files are over here. Is there a way to grant you backend-access?
July 28, 2017 at 4:09 pm #1329903
Bruno
Sure. Please, what steps should I follow to see the problem?
I've downloaded the Duplicator package and I'm going to install it in my testing environment. Also, I've removed the URL above, as this is an open forum.
I'll need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help.
*** Please let me know exactly what steps should I follow to see the problem.
*** Note: Please make a full backup of your site.
Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
