Hi, Amit here, I am the WPML Support Manager, please make sure you are using the latest WPML 4.3.16 before reporting an issue, thanks!
Last updated by Itamar 9 months, 2 weeks ago.
September 19, 2019 at 3:31 pm #4606901
Itamar
Thanks for this extra information.
When our compatibility will check this issue they will determine whether the _bto_data field needs to be set to 'Copy' or 'Don't translate'.
October 2, 2019 at 11:25 am #4679665
Itamar
Hi.
Our compatibility team has found the source of this issue, and we are sharing with you a temporary fix for the issue.
1. Open this file with the code editor program that you are using.
/wp-content/plugins/woocommerce-multilingual/compatibility/class-wcml-composite-products.php
2. Go to line 105 and change this line:
if ( empty($product_translation->original) ) {
With this line:
if ( !empty($product_translations[$product_translation->language_code]->original) ) {
3. Save the change.
Now the problem should not occur again. Please let me know if it is working for you.
The issue is escalated to our developers and will be included in future versions of WooCommerce Multilingual. If you update the WooCommerce Multilingual plugin before the fix is included, please remember to insert the fix again.
I'll keep you updated here when the version with the fix is released.
Itamar.
