Last updated by adrienT-5 8 months, 2 weeks ago.
Assigned support staff: Noman.
September 19, 2019 at 2:35 pm #4606399
adrienT-5
Hi!
I am trying to: add a custom language switcher in my topbar.
So, I try to use the code indicated here at the bottom of the page https://wpml.org/documentation/getting-started-guide/language-setup/custom-language-switcher/
When I paste it to my function.php file in my child theme (Zoa theme), I have a php error.
When I paste the code in a php code tester, I see an error message "Unexpected "<" at line 28.
This is my complete function.php file
<?php
// Filter wp_nav_menu() to add additional links and other output
// Show only other language in language switcher
// Use the new filter: https://wpml.org/wpml-hook/wpml_active_languages/
add_filter('wp_nav_menu_items', 'new_nav_menu_items', 10, 2);
function new_nav_menu_items($items, $args) {
    // uncomment this to find your theme's menu location
    //echo "args:<pre>"; print_r($args); echo "</pre>";
    // get languages
    $languages = apply_filters( 'wpml_active_languages', NULL, 'skip_missing=0' );
    // add $args->theme_location == 'primary-menu' in the conditional if we want to specify the menu location.
    if ( $languages && $args->theme_location == 'primary') {
        if(!empty($languages)){
            foreach($languages as $l){
                if(!$l['active']){
                    // flag with native name
                    $items = $items . '
<li class="menu-item"><a href="' . $l['url'] . '"><img src="' . $l['country_flag_url'] . '" height="12" alt="' . $l['language_code'] . '" width="18" /> ' . $l['native_name'] . '</a></li>
                    //only flag
                    //$items = $items . '
<li class="menu-item menu-item-language"><a href="' . $l['url'] . '"><img src="' . $l['country_flag_url'] . '" height="12" alt="' . $l['language_code'] . '" width="18" /></a></li>
    return $items;
Thanks for your help.
September 19, 2019 at 3:31 pm #4606899
Noman
Thank you for contacting WPML Support. There was an issue due to single line php comment on line number 27. I have used multi line php comment and I hope now it will work fine. Here is updated code:
<?php
    // get languages
                if(!$l['active']){
                    $items = $items . '
                    //only flag
                   /* $items = $items . '
<li class="menu-item menu-item-language"><a href="' . $l['url'] . '"><img src="' . $l['country_flag_url'] . '" height="12" alt="' . $l['language_code'] . '" width="18" /></a></li>';*/
    return $items;
Please let me know if this resolves your issue or you need further assistance with this issue.
Thank you
September 19, 2019 at 3:57 pm #4607047
adrienT-5
