I am trying to translate the "Product" Slug in woocommerce.
So far, we've enabled translation on slug in the settings
We've translated the slug : hidden link
We've tried to disable WooCommerce multilingual, save permalink, translate the slug then re-enable the plugin -> Not working
We've also tried to change theme -> Not working
On frontend, the slug stay the same in both language (we need it to be "Product" in english and "Produit" in french)
We've also noticed a double slash in the permalink settings (weird) : hidden link
Thank you for contacting us. When I try to access your site, this error message appears: ERREUR : ce mot de passe ne correspond pas à l’identifiant Dev. Mot de passe oublié ?
I'm not sure, but it seems that within Settings> General the "Home URL" is using the locale. If so, that would be incorrect.
Could you please verify the username and password again so that I can verify your site? Also, after logging in, what steps should I take to see the problem? Your next message will be private.
Thank you. Now when I try to access your site an http-auth screen is displayed. I will attach a picture for you to see. I tried using the same WordPress credentials, but it didn't work.
Thank you. I fixed the problem by following the steps below:
- Click on the WPML > Settings > Slug translations
- Check the "Translate custom post and taxonomy base slugs (via WPML String Translation)."
- Click on the Save button
- Scroll down and look at the "Post Types Translation"
- Note that the slug is translated to custom type products.
-- hidden link
-- hidden link
Please, let me know if I can help with any other questions you may have about it. I'll be happy to help.
