This topic contains 14 replies, has 4 voices.
Last updated by marco 9 years ago.
May 2, 2011 at 10:58 am #27087
ooluja
Hi to all WPML members 🙂 ,
I have a problem with custom taxonomies.
My taxonomies are: Location, Property Type.
Taxonomies have "hierarchical" set to "true".
WPML version: 2.2.2.1
WP version: 3.1
My taxonomies don't get status "selected" from my default language post. This happens only in hierarchical mode, setting hierarchical to false, it works fine, but I need taxonomies to be in hierarchical mode.
On my default language: (Croatian)
On my second language: (German - nothing selected)
What should I do?
May 2, 2011 at 2:08 pm #27089
Amir
I'm not sure that I follow. We use hierarchical taxonomies too in our own site and we're not seeing a problem.
When you set the taxonomies as hierarchical and choose them in the GUI, are you getting any error?
May 2, 2011 at 2:26 pm #27090
ooluja
No errors.
Maybe something isn't correctly configured in my custom_post_type:
The code that I use:
register_taxonomy( "location",
array( "restate" ),
array ( "hierarchical" => true,
"label" => "Lokacija",
'labels' => array( 'name' => __('Lokacija'),
'singular_name' => __('Lokacija'),
'search_items' => __('Pronađi nekretninu'),
'popular_items' => __('Popularne lokacije'),
'all_items' => __('Sve Lokacije'),
'parent_item' => __('Parent Location'),
'parent_item_colon' => __('Parent Location:'),
'edit_item' => __('Editiraj lokaciju'),
'update_item' => __('Ažuriraj lokaciju'),
'add_new_item' => __('Dodaj novu lokaciju'),
'new_item_name' => __('Ime nove lokacije') ),
'public' => true,
'show_ui' => true,
"rewrite" => true )
The thing is that I can't get the selected taxonomy from the original post to be selected in other translations as well.
In "Multilingual Content Setup" taxonomies are set to "Translate", when translating a post, taxonomy appears in the "translate post"
Picture:
Maybe I'm doing something wrong :/?
May 2, 2011 at 3:52 pm #27091
Amir
Please remove all the gettext calls -
__()
- from the texts in this call. They are what's causing the problem.
May 2, 2011 at 6:52 pm #27092
ooluja
No more gettext calls in this document (theme-custom-post-types.php), but it's still the same 🙁 Can't get the taxonomy selected for other languages.
Do I have to remove "__()" from all documents in the theme?
Thx in advance!
May 2, 2011 at 8:26 pm #27093
Amir
You should keep the gettext calls elsewhere in the theme, just not in the call that registers the custom type.
Do you want us to login to your site and see what may be wrong? If so, I'll write you an email and you can reply to it privately.
May 2, 2011 at 9:31 pm #27094
ooluja
Sure, it would be nice from you Amir 🙂
May 3, 2011 at 6:57 am #27095
Orit
Can you explain
a little more? Perhaps an example, steps to replicate?
May 3, 2011 at 8:59 am #27096
ooluja
Sure,
1. Im adding a property on my default language (Croatian), selecting the taxonomies I would like to use:
then, I click on "publish". Property published.
After that, I choose to translate this property to english:
Im in "translation editor" now. Filling the title and description of the property on english. After that I have to confirm that I will use the translated taxonomies:
Selected "This translation is finished." to all fields.
After translation is saved I don't get the taxonomies selected to the translated property.
Translated property (English):
The taxonomies aren't selected.
Original property (Croatian):
The taxonomies are selected.
And that's my story told in a few steps 🙂
Thx in advance guys 🙂
May 3, 2011 at 9:30 am #27097
ooluja
..and yeah, forgot something.
The file "theme_custom_post_types.php" from the theme:
http://pastebin.com/MrnA4RY9
May 4, 2011 at 9:42 am #27098
ooluja
Found something?
Amir, if it's not a problem for you, I would like if you (or your team) can connect to my website and see what's wrong. I haven't received any email from you yet.
May 4, 2011 at 10:01 am #27099
Amir
Sorry about the delay. I sent you an email.
May 4, 2011 at 1:34 pm #27100
Amir
We fixed this bug in the development version. It will be available in the next release and in the beta versions that we'll have before the final release.
If you want to test using a development version, we can export it for you.
May 4, 2011 at 2:28 pm #27101
ooluja
Sure, thank you Amir, Mihai and others from the WPML team for this great plugin 🙂
May 23, 2011 at 8:13 pm #27102
marco
Hi, I had the same issue with the same wootheme theme (Estate) and I'm recently install the new stable version (2.2.2.1). I'm just found this post, and I see isn't possible fix this in this new version?
is there a quick solution for this? or, when you will release the new stable version (2.3)? i don't want to install the release candidate and had new issues =(
help!
The topic ‘[Closed] Custom taxonomies hierarchical problem’ is closed to new replies.
