Last updated by Bobby 12 months ago.
Assisted by: Bobby.
October 15, 2024 at 12:20 am #16288104
Kresimir
We have two custom taxonomies for WooCommerce products, created using Extended CPTs (hidden link), to have a single-select dropdown for choosing the taxonomy. We have over 1000 products and 6 languages on the site. Custom fields are registered using ACF and are set to 'copy' or 'copy once'.
When I duplicate products to other languages, those taxonomies do not get copied to the product. Custom fields do not get copied to the duplicated products until I edit the duplicated product and save/update it.
Why are custom taxonomies not copied when duplicating products to other languages?
Why do custom fields registered using ACF not get copied until I edit and save the duplicated product?
October 15, 2024 at 8:23 pm #16292588
Bobby
WPML Supporter since 04/2015
Please review this errata documentation and try the workaround:
https://wpml.org/errata/acf-duplication-issue-field-types/
Let me know your results.
October 17, 2024 at 2:44 pm #16301074
Kresimir
Hey,
I don't know how to implement it for my case. I have two issues:
1. Custom taxonomies are not copied. They are assigned to a product just like WooCommerce product categories are, they do not depend on ACF.
2. The problem with ACF is that repeater field doesn't get copied until I enter and update the product.
October 18, 2024 at 9:03 pm #16306534
Bobby
Thank you,
Bobby
October 25, 2024 at 7:04 pm #16332034
Bobby
Using this product: hidden link
and reviewing its translation hidden link
Everything looks OK, I assume because you did the following "edit and update translated product", correct?
On the same product, I duplicated it to Hungarian and it seems to be working OK without me having to update it again. Am I missing something to reproduce the issue?
You can see my steps here:
October 28, 2024 at 8:34 am #16336318
Kresimir
Hey Bobby,
Like I mentioned, the only thing I still have an issue with is "energy_certificates" repeater field.
For example if you look at this product in original language you'll see those energy certificates - hidden link
But they do not get copied to translated language - hidden link
October 28, 2024 at 5:46 pm #16339315
Bobby
Thank you for the clarification.
I am testing this using the product shared and will update you!
October 29, 2024 at 10:28 pm #16344361
Bobby
I believe implementing the fix shared earlier with you in the functions.php should resolve this issue.
At the moment I am not able to locate the Field Groups area to edit the ACF Field Groups on the site, is it missing or hidden? I can see that ACF Pro is activated.
The topic ‘[Closed] Custom taxonomies not copied when duplicating products to other languages’ is closed to new replies.
