Last updated by mazenA-5 10 months, 1 week ago.
July 19, 2019 at 12:47 am #4242695
mazenA-5
I am trying to remove WPML translation and RTL to the Code Module of Divi that's used to show up the shortcode of Calendarista plugin. The page was translated to Arabic (as required) but we are encountering an issue with the Calendarista's pop-up calendar while on the translated page. After looking for other ways, we figured it might be easier to disable the translations on the Calendarista even if the other aspects of the page got translated using WPML.
None, Calendarista wasn't even shown on the Advanced Translator.
This is the link that goes directly to the Arabic translated page -> hidden link
Please test by clicking on the Select A Date field and then click the small black triangle that represents movement into different months. That's a bug that we want to get removed so we'd rather Calendarista doesn't get translated at all or doesn't get affected by WPML when it triggers RTL support.
Thank you in advance for your help!
All the best.
July 19, 2019 at 10:25 am #4245679
Raja Mohammed
The issue is related to handling RTL style by the plugin since the page loaded with RTL formatting and the calendar with RTL style is either broken or not loaded properly, I did a little bit of debugging to confirm the issue by changing the calendar style to LTR instead of RTL and it seems to work good please refer hidden link
I would suggest referring the issue to the plugin author they can help you better with a solution.
Kind regards
Raja
July 22, 2019 at 11:26 am #4256531
mazenA-5
