Last updated by yao-yuT 1 year, 3 months ago.
October 1, 2019 at 1:34 am #4667907 | |
yao-yuT |
Tell us what you are trying to do? After downloading and activating WPML, my website started to face display problem in many pages, the previous display mode is still there when checking by backend WPBakery Page Builder, which is showed in enclosed file. Please help fix the bug so my page can display properly as usual, thank you! Is there any documentation that you are following? No. Is there a similar example that we can see? Example in enclosed file What is the link to your site? hidden link |
October 1, 2019 at 11:59 am #4671815 | |
yao-yuT |
yes? |
October 1, 2019 at 11:59 am #4671817 | |
Raja Mohammed Supporter
Languages: English (English ) Timezone: Asia/Kolkata (GMT+05:30) |
Hello there, I have taken over this ticket now. Please create a snapshot site and pass on the archive link here. You can use the Duplicator plugin to create a snapshot of the site and share the package link with me http://wordpress.org/plugins/duplicator/. I have enabled private fields for you to securely share the details. |
October 1, 2019 at 12:03 pm #4671853 | |
yao-yuT |
No prob, working on it. |
October 1, 2019 at 12:20 pm #4671947 | |
yao-yuT |
hidden link |
October 1, 2019 at 12:23 pm #4671961 | |
yao-yuT |
Can u reach the file? thank u. |
October 2, 2019 at 7:50 am #4677569 | |
yao-yuT |
Are u there Raja? it's been 15 hours without reply after u taking over this ticket.... |
October 3, 2019 at 3:29 am #4684347 | |
Sorry for the delay I was away yesterday. |
October 3, 2019 at 7:35 am #4685177 | |
Thanks for your patience, Following are my observations and suggestion - Your site default language is set to Chinese but there are no products created in the Chinese language. - You have set product translation setting to Fallback to default when there is no translation available, This will work only when you have products created in the Default language (Chinese) Please follow these suggestions, - If the above suggestion is not an option then follow these steps, --- Delete the shop page and its translation, Remove it from the trash --- Create a new shop page in English and translate it to Chinese --- Goto WooCommerce > Settings > Products, Change the language to "All language" from the topbar. Choose the shop page to the one that is created in the English language --- Once done Goto WPML > Support > Troubleshooting, Click on the following buttons Following these steps resolved the issue in my local installation I hope this helps resolve your issue. |
October 3, 2019 at 9:19 am #4686255 | |
yao-yuT |
Thank you Mohamned, I'll follow your steps and try today. also for another big issue after using WPML is that massive of my images turns into ? or not displaying either backend / frontend after using WPML, for this situation, what shall I do to fix them? It was all uploaded before using WPML. |
October 3, 2019 at 9:28 am #4686305 | |
Thanks, I will await your response. Thanks again for creating a separate thread for the new issue, I have responded to the media issue in a separate thread which you have created https://wpml.org/forums/topic/massive-media-library-images-turned-into-after-using-wpml/#post-4686279 I would prefer to restrict the discussion of this thread only to the shop issue 🙂 |
October 6, 2019 at 6:18 am #4701731 | |
yao-yuT |
My issue is resolved now. Thank you! |
