Last updated by Lauren 2 years, 4 months ago.
March 16, 2018 at 4:05 pm #1548221
nathanD-4
I am trying to: Have the same page between original language and traduec language
- Original Page : hidden link
-Traduced Page : hidden link
I expected to see : The same page, which displays exactly the same content but there 's problem, because
Instead, I got: The first part, but when it arrived to the quotation , it disappears
March 19, 2018 at 9:39 pm #1550172
Lauren
Can you tell me a little about how you add this content to the page? Are you using a plugin, or page builder, to create this content?
If you go to WPML -> Translation management -> Multilingual Content Setup, make sure the checkbox to synchronize page templates is selected.
Also, please try increasing the WP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Add it above the line /* That's all, stop editing! Happy blogging. */
March 21, 2018 at 4:08 pm #1552604
nathanD-4
Thanks for yor reply.
I have done all the things indicated in your replay , but it is still not working ..
For the content, each product page is a woocommerce product, with 2 plugins : Woocommerce Measurement Price Calculator , linked to Woocommerce Yith request a quote. After that, there's a shotcode showing the related products, and an image content which is not visible is managed by Woocommerce
March 22, 2018 at 3:03 am #1553122
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
The topic ‘[Closed] Display problem with original language and traduction’ is closed to new replies.
