Last updated by Marcel 10 months, 2 weeks ago.
Assigned support staff: Marcel.
July 22, 2019 at 12:40 pm #4257289
andreasZ-23
I am trying to: Edit any existing page with the Divi Builder
I expected to see: The existing content of the page within the Divi Builder
Instead, I got: Only Footer is visible; when wmpl plugin is deactivated, the divi builder works perfectly fine
July 22, 2019 at 2:58 pm #4259027
Marcel
Hi Andreas,
Thank you for contacting WPML Support. We are fully compatible with the Divi Theme. Could you please check the following?
#1 Please increase your WP memory limit. PHP memory is fine, but WordPress uses 40Mb as default. Minimum requirements for WPML are 128Mb: https://wpml.org/home/minimum-requirements/
Add this to the top of wp-config.php to increase WP memory:
/** Memory Limit */
#2 Could you please add me your PHP error log? WordPress includes a debug mode which helps reveal PHP problems.
To enable it, open your wp-config.php file and look for
define('WP_DEBUG', false);
Change it to:
define('WP_DEBUG', true);
In order to enable the error logging to a file on the server you need to add yet one more similar line:
In this case, the errors will be saved to a debug.log log file inside the /wp-content/directory.
Depending on whether you want your errors to be only logged or also displayed on the screen you should also have this line there, immediately after the line mentioned above:
define( 'WP_DEBUG_DISPLAY', true );
The wp-config.php is located in your WordPress root directory. It’s the same file where the database configuration settings are. You will have to access it by FTP or SFTP in order to edit it.
If you open wp-config.php and that define statement is not there, you can add it right before this line:
Please note that you’ll see everything, not only related to our Plugins.
This will most likely include messages from other plugins, your theme and sometimes even WordPress core. The messages appear all over the place.
Sometimes they appear right on top, but they can also appear in the middle of the page.
DOC:
https://codex.wordpress.org/Debugging_in_WordPress
Please report me the errors you are seeing. You can also reply me in German 🙂
Kind Regards
Marcel
July 22, 2019 at 3:33 pm #4259573
andreasZ-23
Hallo Marcel,
zunächst einmal vielen Dank für die schnelle Rückmeldung!
Ich habe die wp-config.php wie empfohlen angepasst, das WP Memory Limit liegt jetzt laut der Ausgabe des Plugins "Server IP & Memory Usage Display" auch bei 256MB. Leider lässt sich der Divi Builder trotzdem noch nicht aktivieren.
Gerne hätte ich dir auch ein PHP-Logfile mitgeschickt, allerdings finde ich im wp-content Verzeichnis keine entprechende Logdatei...
Nachfolgend eine Übersicht der hinzugefügten Zeilen in der wp-config.php:
<?php
/** Memory Limit */
define('FS_METHOD', 'direct');
Die genutzte PHP-Version lautet PHP 7.3.6 @64BitOS
Viele Grüße
July 22, 2019 at 3:37 pm #4259609
Marcel
Hallo Andreas,
Ihre nächste Antwort ist als „Privat“ markiert, dies bedeutet nur Sie und ich haben Zugriff darauf.
❌ Bitte sichern Sie Ihre Datenbank und Website davor ❌
✙ Ich würde außerdem Ihre Erlaubnis benötigen, um Plugins und das Theme zu deaktivieren und erneut zu aktivieren sowie Konfigurationen auf der Seite zu ändern. Dies ist auch der Grund, warum das Backup wirklich wichtig ist.
Freundliche Grüße
Marcel
July 22, 2019 at 4:00 pm #4259765
andreasZ-23
Hallo Marcel,
das klingt nach einem guten Plan, allerdings werde ich das heute zeitlich nicht mehr hinbekommen. Daher würde ich mich morgen im Laufe des Vormittags noch einmal melden. Ich hoffe das geht in Ordnung.
Viele Grüße
July 22, 2019 at 4:05 pm #4259791
Marcel
Kein Problem, die nächste Antwort ist als privat markiert, Sie können die Logindaten somit jederzeit sicher übermitteln.
Freundliche Grüße
Marcel
July 23, 2019 at 11:16 am #4265451
Marcel
Hallo Andreas,
Vielen Dank. Im Log war Folgendes:
[23-Jul-2019 09:33:07 UTC]  .../components/init.php:278  et_core_page_resource_get():
Removing extra page resource file: /homepages/24/d772053608/htdocs/clickandbuilds/MoresophyRelaunch2019/wp-content/cache/et/global/et-divi-customizer-global-1563873396718.min.css
Folgende Tests habe ich durchgeführt.
- Alle Plugins außer WPML deaktiviert
- Divi Builder Cache bereinigt
Ich konnte das Problem auf einer isolierten Sandbox Umgebung mit der neuesten Divi Version nicht nachstellen. Ebenso habe ich Ihre Seite auf unseren Cloudways Server migriert, wo dies ebenso funktionierte.
Es liegt somit an Ihrer Installation. Bitte kontaktieren Sie Ihren Hoster und fragen Sie nach den vollen PHP Error Logs. Möglicherweise finden wir hier einen Anhaltspunkt.
Sie können die Testseite mit Ihren Login Details auf hidden link überprüfen.
Freundliche Grüße
Marcel
July 23, 2019 at 11:40 am #4265607
andreasZ-23
Hallo Marcel,
vielen Dank soweit. In der Testumgebung scheint in der Tat alles ohne Probleme zu funktionieren. Irgendwelche Ideen, worum es sich bei der im Log ausgegebenen Fehlermeldung handeln könnte? Eine kurze Google-Recherche dazu hat meinerseits keine Ansatzpunkte liefern können...
Viele Grüße
July 23, 2019 at 12:42 pm #4265983
Marcel
Hallo Andreas,
es sieht nach einem Problem mit dem CSS Caching bzw. dem CSS Minifier zu sein, die Fehlermeldung sagt leider nicht viel aus. Ich habe bereits versucht den Divi Builder Cache zu bereinigen. Möglicherweise haben Sie ein Extra Cache am Server aktiv?
Prüfen Sie am besten Ihr PHP Error Log mithilfe Ihres Hosters oder kontaktieren Sie direkt den Divi Support.
Freundliche Grüße
Marcel
July 23, 2019 at 1:18 pm #4266421
andreasZ-23
Hallo nochmal,
alles klar, dann werde ich mich zunächst mit IONOS bzw. Divi in Verbindung setzen und zu einem späteren Zeitpunkt hier noch einmal melden...
Viele Grüße
July 23, 2019 at 1:20 pm #4266429
Marcel
Vielen Dank für die Info! Geht in Ordnung.
Freundliche Grüße
Marcel
