Last updated by alexanderW-44 9 months, 3 weeks ago.
Assigned support staff: Noman.
July 31, 2019 at 6:09 pm #4317235
alexanderW-44
I am trying to: translate the divi code module.
I expected to see: the code module for translation.
Instead, no code module is visible in the transaltion. I even updated the XML as per an old support ticket, code can be seen below.
<wpml-config>
    <shortcodes>
        <shortcode>
            <tag>et_pb_code</tag>
            <attributes>
                <attribute>background_image</attribute>
                <attribute>background_video_mp4</attribute>
                <attribute>background_video_webm</attribute>
            </attributes>
        </shortcode>
    </shortcodes>
</wpml-config>
August 1, 2019 at 4:53 am #4318721
Noman
- Go to Plugins >> Add new >> Commercial >> and click on "check for updates" and update WPML plugins.
- Edit the translation and finish it as it is (mark it as 100% Translated).
- Make a small change in the original page, for example, a space in your title.
- Edit the translation again.
Does it work this time? If still issue persists, please follow below steps and let me know how it goes?
1. Please upgrade your server’s PHP version to a higher level: https://wpml.org/home/minimum-requirements/
PHP is 5.6.40 which is good, but it's advised is to use more up-to-date version for better performance and stability. You can contact your website hosting company to upgrade this for you.
2. Please add this to the top of wp-config.php to increase WP memory:
/* WP Memory Limit */
define('WP_MEMORY_LIMIT', '512M');
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
3. Please delete all sorts of caches on your site / server cache (if any) / plugin cache / CDN cache (if any), clear browser cache and see if this resolves your issue.
Thank you
August 6, 2019 at 1:54 pm #4348017
alexanderW-44
