Last updated by Bruno 1 year, 8 months ago.
April 10, 2019 at 8:43 pm
ipsow
I am trying to:
WPML is set with 2 domains for 2 lang.
domain.fr for french
domain.com for english
Process to see the problem :
I connect to domain.com admin
I go to page listing
I click to french filter to see only french page
I click to a page using DIVI BUILDER of DIVI THEME
The builder don't load, I can see on browser console that the DIVI BUILDER try to load with the domain.fr but we are in domain.com so cross origin block the call.
admin side
I expected to see:
The DIVI BUILDER fully loaded.
Instead, I got:
Nothing.
I saw on forum, some complain with same problem with elementor or other visual builder.
I'm in contact with DIVI support, but they seems not have a solution. I asked them to contact your team, but of coure they will not.
So please someone fix this here...
best regards
April 10, 2019 at 11:26 pm #3581913
Bruno
Thank you for contacting us. This seems like the problem is related to the "Coming Page" plugin that you are using. Probably disabling this should the content be displayed correctly.
If the problem persists, please as a test, could you disable all non-WPML plugins, switch to the default theme and see if the problem persists?
If the problem is fixed, please, enable the plugins one by one to see if there is any compatibility problem between these plugins.
April 11, 2019 at 10:06 am #3585931
ipsow
I did the test.
When I desactive the maintenance mode, i do the process to get the original issue.
Now, I see the front-end homepage inside the builder and the loading icon over.
I disable some plugins and of course i can't set the default theme because the problem is with the builder of the theme...
Nothing change I see the front-end inside the builder...
April 11, 2019 at 10:42 am #3586235
ipsow
DIVI Theme has for few months a new builder, who is displayed inside an iframe.
the url of this iframe switch the url according to the lang and use the domain linked to the lang.
i'm in the domain.com (english) i open a page in french, the builder load an iframe with domain.fr
it show the front-end depending of the page with a 404 (inside the builder because it's an iframe)
If i open a page in english, no problem. the iframe load the builder.
DIVI theme give the possibility to use the old builder (less options)
This old one, seems not be an iframe, so there is no problem in both lang.
April 13, 2019 at 2:42 am #3602901
Bruno
Thank you. So that I can better test your site, please, can I install the Duplicator plugin (or All in One Migration) to make a copy of your site and install it on my test environment? This will help me debug the problem.
April 13, 2019 at 8:24 am #3603941
ipsow
Yes sure.
April 17, 2019 at 12:34 am #3626185
Bruno
Thank you. Sorry for the delay. I've installed All in One Migration plugin and I did a copy of your site. I will install it on my test environment and soon I will contact you.
April 19, 2019 at 7:42 pm #3648119
Bruno
Sorry for the delay. I was able to replicate the problem you are reporting.
This seems to be a compatibility problem. Note, however, that this is not the way to translate content using Divi and WPML. The recommended way is to translate the content using the Translation Editor.
Anyway, I've forwarded this bug to our compatibility team. As soon as they test your site I'll keep you posted.
April 19, 2019 at 10:10 pm #3648299
ipsow
yes i know this is not the "traditional" way to translate.
It's just if I need to do a different page design with the divi builder on the other lang, well it's broken.
Currently the solution is to connect to the corresponding lang domain dashboard to do what i want.
I will wait an easiest fix.
thank you
April 20, 2019 at 2:53 am #3649005
Bruno
Sure. As soon as 2nd tier support checks the problem, I'll keep you posted.
May 10, 2019 at 8:57 pm #3787771
Bruno
Sorry for the delay. Our compatibility team said they are aware of this problem and this will be fixed in a future version of WPML.
At the moment, unfortunately, we do not have a deadline when this is going to be fixed, but it should not take long.
