This topic contains 18 replies, has 2 voices.
Last updated by tonyD-4 6 months, 3 weeks ago.
Assigned support staff: Osama Mersal.
March 9, 2022 at 4:03 am #10745645
tonyD-4
This page has a Divi video module where I am adding a vimeo link to it. The video works on English (Default) but the video does not work on Chinese version
March 9, 2022 at 10:12 am #10747705
Osama Mersal
1) Could you please check the following steps?
1- Edit the page in English
2- Switch the language using the top admin bar
3- Check the video module on the translated page
4- Make sure it's configured correctly, and click on the update
5- Check if it works correctly on the front end
2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. Minimum requirements for WPML are 128Mb. (Kindly check this page https://wpml.org/home/minimum-requirements/)
Add this to the top of wp-config.php to increase WP memory:
/** Memory Limit */
I hope this helps you. If you need further info, please let me know.
Osama
March 9, 2022 at 8:16 pm #10753787
tonyD-4
When I tried to follow the step 2, the Divi builder didn't work for hidden link.
Then I ticked the option 'Auto sign-in and sign-out users from all domains' in side WordPress Dashboard > WPML > Languages > Language URL format. Then logged out from the English version and logged into the Chinese version hidden link and then tried to edit the page. That was successful. The Divi builder was loading fine. Looks like you need to login to a the website when you use different domain with WPML
The I followed from step 3 to 5. But the video is not working.
March 9, 2022 at 8:19 pm #10753793
Osama Mersal
Thanks for your update. I would need to take a closer look at your site. So I would need to request temporary access (WP-Admin and FTP)
in order to be of better help and check if some configurations might need to be changed
Your next answer will be private, which means only you and I have access to it.
✙ I would need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if needed. This is also a reason the backup is critical.
Thanks for your cooperation
Osama
March 9, 2022 at 8:42 pm #10753851
tonyD-4
I think I found the issue. This happens because of the hidden link.
I changed the language to be Chinese from the tool bar and disabled the script blocker for Vimeo. That solves the problem
But It should not happen even if it's enabled Because I have accept all the cookies on the site for some reason it does not work for other subdomains.
I don't think I could set up a dev site for you. But I can give you the permission to take a copy of it. Do you still need FTP logins or, do you have a solution for the above
March 9, 2022 at 8:49 pm #10753929
Osama Mersal
I think you found a workaround to fix the Divi video module by disabling the script blocker for Vimeo in the Chinese language.
If you deactivated the script plugin, do you face the same issue?
Osama
March 9, 2022 at 9:39 pm #10754143
tonyD-4
Yes, that works. But I do not want to do that. It works as expected on English language but not the others. I would want to know why is that. Because Accepting cookies is important and I need to make sure all the three languages has the same policy.
March 9, 2022 at 9:47 pm #10754155
Osama Mersal
May I ask you to run the following tests to know what is causing the issue?
1) Language URL Format test:
Please go to WPML-> Languages, and select "Different languages in directories". After that, please clear your site's cache and delete the cookies from your browser and check if the issue persists.
2) Minimal installation test:
If the issue persists, please check if the issue persists in a minimal environment by following these steps:
1- Deactivate all the plugins except WPML CMS and the script blocker plugin.
2- Switch for a moment to a WordPress default theme like Twenty Twenty-one.
If the issue is gone, activate one by one to see which one is causing an interaction issue.
❌ Please backup your database before performing the above test ❌
Would you please let me know the result of these tests? These tests will help us understand if the issue is caused by the language URL format or a plugin conflict.
Osama
March 9, 2022 at 9:56 pm #10754165
tonyD-4
It works with directory format
March 9, 2022 at 10:00 pm #10754173
Osama Mersal
Thanks for your update. Could you please share the dashboard login details to check it?
Osama
March 9, 2022 at 10:25 pm #10754319
Osama Mersal
Thanks for the access details. I've checked your site and set the "GDPR Cookie Consent (cookielawinfo)" post type along with the "Cookie Category (cookielawinfo-category)" taxonomy to be "Translatable - use translation if available or fallback to default language". (Kindly check this hidden link)
After that, I've checked the translated page, and the video worked correctly. (Kindly check this hidden link)
Would you please check it and let me know if it works at your end?
Osama
March 9, 2022 at 10:42 pm #10754365
tonyD-4
Thanks! That works.
Can you explain what was the reason for the issue?
March 9, 2022 at 10:45 pm #10754369
Osama Mersal
It's great to hear that it's working now. You might need to translate or duplicate the Cookie List and Cookie Categories because they are not translated, and I think that's what causes the issue.
Cookie-List: hidden link
Cookie Categories: hidden link
Osama
March 9, 2022 at 10:47 pm #10754371
tonyD-4
Can I do that via downingpoc.co.nz instead of login to the cn. version
March 9, 2022 at 10:49 pm #10754379
Osama Mersal
Yes, you can do it from the main domain. I just copied the URLs while logged in to the subdomain.
Have a good day!
Osama
