Last updated by Carlos Rojas 3 months ago.
October 12, 2019 at 12:23 pm #4742913
hussainB
I am trying to:
Translate simple and variant products on designletters.com.
I expected to see:
In general, there are issues when duplicating and translating. Is it correct that i need to go to each language and publish the product? Also the plugin creates issues when duplicating landingpages and in the menu. It does not act the same way in all languages, when I make a change.
October 14, 2019 at 12:29 pm #4749765
Carlos Rojas
Could you elaborate more about this issue so I can have a better understanding? Also, please attach some screenshots that show the problem.
Kind regards,
Carlos
October 21, 2019 at 1:57 pm #4795031
hussainB
Hi. If you look at the two screen shot, you see the difference on our UK site (The primary where we add new products) in the variants. On the eur site, it does not show the thumbnail pictures. The eur page is duplicated from the uk.
October 21, 2019 at 3:27 pm #4795769
Carlos Rojas
Could you describe the steps you are following to duplicate the products?
Carlos
October 22, 2019 at 2:03 pm #4803109
hussainB
Sure.
1. Add a new product on our uk site (GBP) with a primary sku, create variants from attributes, applies four prices (for each currency) on all variants and variant images. Next I apply a thumbnail image of the variant in swatches.
2. when all these fields are filled, I use the WPML box in the right corner and duplicates it the EUR, USD and GER site. And translates the DKK.
But the swatches are not copied on the duplicated sited. After I wrote you about the same problem when translating it worked with your help.
If i apply the swatches on the duplicated sites instead, it will not save the changes anyway.
I hope this helps.
October 22, 2019 at 4:23 pm #4804261
Carlos Rojas
Our Debugging Procedures
Carlos
October 23, 2019 at 10:58 am #4810473
Carlos Rojas
Before we continue I kindly ask you to update all outdated plugins and themes and flush all cache memory. This way we will be able to rule out any issue that might be solved already in the latest plugins/theme version.
Carlos
October 24, 2019 at 10:47 am #4818741
hussainB
Hi Carlos,
I just updated the plugins that I can in the moment. Could you please have a look at the site now?
October 24, 2019 at 11:22 am #4818939
Carlos Rojas
I tried to log in the site but the credentials failed. Could you double check if the credentials are still correct?
Carlos
October 24, 2019 at 1:41 pm #4820751
hussainB
Hi Carlos,
Sorry we had to do a backup from yesterday, so we do not have the plugins updated anyways.
October 24, 2019 at 2:11 pm #4821171
Carlos Rojas
Thank you for your feedback, however I still can't login the site using the credentials provided. Could you double check this?
Carlos
