Last updated by srdjan 1 year, 7 months ago.
Assigned support staff: srdjan.
October 7, 2018 at 6:52 pm #2794177
geraldined-2
Edge Slider: I translated all the slides and briefly had this working. Then it stopped?!
October 8, 2018 at 8:29 am #2795100
srdjan
Hello Geraldined,
are talking about Artbees Edge Slider shortcode (for Visual Composer)?
Can you remember when it stopped?
(on some update, plugin activation, any other change)
October 8, 2018 at 8:49 am #2795176
geraldined-2
Here is the debut info. It is Artbees Edge Slider I believe. The one that comes with the Jupiter theme. It was working absolutely fine and then it wasn't. The only thing that I did in between those two things was add a page to the French menu. I have since tried removing this to see if it went back, but it doesn't. It works on the original English version just not on the translated page.
October 8, 2018 at 1:25 pm #2796113
srdjan
Hi Geraldined,
I just checked Jupiter at our test site and Edge Slider appears working fine.
I need more info to replicate issue:
- How you translated slides? (are translations appearing fine in backend)
- Have you checked if Visual Composer Edge Slider cell is correctly set for other language?
- Have you used plain shortcode?
Also it would help if you can give us access to your backend so we can see issue.
Also Duplicator export would help to replicate and debug issue.
I set next reply as private so you can share link to one of these if you wish to do so.
The topic ‘[Closed] Edge Slider not working’ is closed to new replies.
