This topic contains 16 replies, has 9 voices.
Last updated by Laura 2 months, 2 weeks ago.
February 27, 2019 at 9:34 am #3249279
marcL-35
The Elementor maintenance mode is not working when WPML Multilingual CMS is activated.
It looks like the issue is well known but some support ticket mentioned that the issue is closed with an update. I am using WPML 4.2.2 and i still have the issue
Is there anything i can do to get the Elementor maintenance mode working?
Thank you
Best Regards,
Marc
February 28, 2019 at 2:49 am #3253280
Bruno
Hello there,
Thank you for contacting us. Please, my sincere apologies for the delay in answering. I was able to replicate the problem you are reporting.
To ensure that this plugin is made fully compatible with WPML we need to contact the plugin author and work with him on resolving the issue.
I have forwarded the details to our Themes & Plugins Compatibility Team and they will contact the author. Our Compatibility Team will work with the author of the plugin for this to work properly.
Please note that this process may take a while as it depends on how soon the author will reply to our efforts to contact him.
March 20, 2019 at 1:28 pm #3388695
marcL-35
Hi Bruno, have you got more information on the above?
Thank you
Kind Regards,
Marc
March 22, 2019 at 4:11 am #3437439
Bruno
Hi Marc,
At the moment 2nd tier support has already verified the problem, and managed to replicate it, but at the moment we do not have a workaround for this.
When 2nd tier support provides some workaround or some patch to fix the problem, I'll contact you.
March 22, 2019 at 8:41 am #3438595
marcL-35
Thank you Bruno for your reply,
Has the external party giving you a timeframe? Just wonder if we are looking at weeks or month?
Have a good day
March 22, 2019 at 1:08 pm #3440471
Bruno
Unfortunately, I do not have a deadline when this is going to be fixed. Basically, I referred to the 2nd tier support that was able to replicate the problem.
Now it is necessary to wait for our developers so they can check what is going on and how this is going to be fixed. For this reason, I could not determine a deadline.
April 3, 2019 at 8:19 am #3523503
marcL-35
Hi Bruno,
Any update on the problem? Have you managed to contact the 2nd tier?
Thank you
Have a good day
Marc
June 27, 2019 at 1:37 pm #4100437
wilfredC-2
...still no solution, same problem here!
September 16, 2019 at 12:05 am #4575531
edoardoG-2
same problem
October 28, 2019 at 10:54 am #4838469
marcL-35
Hi all,
Will it be possible to have an update ?
It is still not working.
Thank you
October 31, 2019 at 10:54 am #4862777
marcL-35
Hi all,
This issue has been ongoing for more than a year...
Does anybody has a solution ?
Thank you
November 5, 2019 at 11:06 am #4887957
florianS-4
Hi there !
Just updated to 4.3.3, and still having the same problem..
planning to fix it ?
November 16, 2019 at 11:31 am #4958039
tarmoI
same problem, when WPML Multilingual CMS is activated my elementor coming soon is showing white page.
November 16, 2019 at 11:34 am #4958041
tarmoI
workaround for this:
- Click on the WPML > Languages > Browser language redirect, make sure the option is disabled and click on the Save button
- On the "SEO Options", make sure the "Display alternative languages in the HEAD section." option is disabled and click on the Save button
February 6, 2020 at 12:50 pm #5438969
wimH-2
tarmoI's solution worked for me!
