This topic contains 9 replies, has 3 voices.
Last updated by miguel-angelH-4 1 year, 3 months ago.
March 1, 2019 at 7:56 pm #3263093
jean-philippeU
I am trying to translate some strings in the Archive Posts widget, namely the label for "Read more" and the message "No posts found" that are fields within the Elementor Panel for the Archive Posts Widget. These fields do not appear in the WPML Translation Dashboard when translating a template in the Theme Builder.
Is the Archive Posts fully translatable ? How do I translate the strings in the widget field ?
Cheers,
March 4, 2019 at 12:28 pm #3268590
Raja Mohammed
Welcome to our forum,
The Settings texts of Elementor can be translated from WPML > String Translation.
Search for the string that needs to be translated and add your translations there.
Please refer https://wpml.org/documentation/getting-started-guide/string-translation/#translating-strings
I hope this would help in your case. Let me know if you need further clarification.
Kind regards
Raja
March 4, 2019 at 6:16 pm #3270298
jean-philippeU
Hey Raja,
The strings do not get picked up by String Translation.
What could be the problem ?
Cheers,
March 5, 2019 at 5:35 am #3271729
Raja Mohammed
I would like to request temporary access (wp-admin and FTP) to your test site to take a better look at the issue.
Kind regards
Raja
March 6, 2019 at 7:27 am #3277229
Raja Mohammed
Thanks for the access, I am not able to figure out any solution for the issue for better clarity It would be good if you can provide me with the WordPress debug.log (not WPML debug information).
To enable it, open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
define('WP_DEBUG', true);
In this case, the errors will be saved to a debug.log log file inside the /wp-content/ directory.
If you can paste your debug.log to pastebin.com and provide me that link it would be great! (This is the cleanest way because sometimes the logs are long and create a complete mess in the discussion).
If there is nothing in debug log, I will take a clone of your site in our private server for a detailed investigation.
Please also check if you have any server cache enabled like varnish, Memcache etc. try clearing them.
Let me know the results,
Kind regards
Raja
March 6, 2019 at 1:59 pm #3279455
jean-philippeU
Hi Raja,
I've added the required declarations and also set WP_DEBUG_DISPLAY to false.
I'll wait 24h before submitting the debug log.
Cheers,
JP
March 7, 2019 at 9:31 am #3283180
Raja Mohammed
Hi Jp,
Thanks, Share with me when you can access the debug logs.
Kind regards
Raja
March 7, 2019 at 3:30 pm #3285341
jean-philippeU
Here is the current output :
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 114
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 121
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 125
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 128
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 131
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 153
[06-Mar-2019 17:12:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-includes/post-template.php on line 298
[06-Mar-2019 17:20:33 UTC] PHP Notice:  Undefined offset: 0 in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/acfml/classes/class-wpml-acf-editor-hooks.php on line 16
[06-Mar-2019 17:20:38 UTC] PHP Notice:  Undefined offset: 0 in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/acfml/classes/class-wpml-acf-editor-hooks.php on line 16
[06-Mar-2019 17:20:41 UTC] PHP Notice:  Undefined offset: 0 in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/acfml/classes/class-wpml-acf-editor-hooks.php on line 16
[06-Mar-2019 17:23:18 UTC] PHP Notice:  Undefined offset: 0 in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/acfml/classes/class-wpml-acf-editor-hooks.php on line 16
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 114
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 121
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 125
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 128
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 131
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 153
[06-Mar-2019 23:51:48 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-includes/post-template.php on line 298
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 114
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 121
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 125
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 128
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 131
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 153
[06-Mar-2019 23:51:53 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-includes/post-template.php on line 298
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 114
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 121
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 125
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 128
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 131
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 153
[06-Mar-2019 23:51:57 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-includes/post-template.php on line 298
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 114
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 121
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 125
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 128
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 131
[06-Mar-2019 23:52:31 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-content/plugins/elementor-pro/modules/theme-builder/widgets/post-content.php on line 153
[06-Mar-2019 23:52:32 UTC] PHP Notice:  Trying to get property of non-object in /home/jacketj/public_html/SITE_jeunesqueeryouth.org/wp-includes/post-template.php on line 298
March 8, 2019 at 6:17 am #3289488
Raja Mohammed
Hi Jp,
Thanks for the debug info. However, there is nothing much detail in the logs. I am suspecting it to be related to issues with MaxInpuVars.
Please increase the Php Max_input_vars limit to 5000, You can follow the below link on how to do it or request your hosting provider to help you in this case.
If that doesn't help I will take a clone of your site to our private server for further investigation.
Let me know the results.
Kind regards
Raja
May 12, 2019 at 2:47 pm #3793179
miguel-angelH-4
I have the same problem and I have tested to increase max_input_vars
WPML works perfect with Posts and I can translate "Read More", Pagination and so on, but with Archive Posts I have the problems that indicate jean-philippeU, I don't see them.
Any solution?
Thank you
