Last updated by fernandoG-22 1 month, 2 weeks ago.
Assigned support staff: Osama Mersal.
December 4, 2021 at 9:27 pm #10127047
fernandoG-22
I am trying to:
be translated the Elementor section IDs when user are logged
I expected to see:
the Elementor section IDs are translated when user are not logged
Instead, I got:
section IDs with wrong language
December 7, 2021 at 12:40 pm #10139869
Osama Mersal
1) Sorry for the late reply. Kindly go to WPML-> Languages-> Language filtering for AJAX operations and enable it.
2) If that didn't fix the issue, could you please edit the translated page using Elementor and check the section ID? If it's not the proper ID for the language, kindly set the correct ID and check if that fixes the issue.
Alternatively, update the page translation and search for the ID to check if it's translated correctly.
I hope this helps you. If you need further info, please let me know.
Osama
December 7, 2021 at 1:10 pm #10140097
fernandoG-22
