We have a longer than usual waiting time. Please make sure to check out the Known Issues page and Minimum Requirements before reporting any issue.
Last updated by Long Nguyen 6 months ago.
Assisted by: Long Nguyen.
May 16, 2024 at 1:08 pm #15635244
raviS-7
I am having one ACF Text field which is set with "Translate" as I can see in "Custom Fields Translation" option in WPML settings. If there is already value in that field and I replace or update value with some other value, then after translation, it's perfect for other languages. But if I am replace existing text value with empty string value then after translation, it's not update for other languages.
May 17, 2024 at 2:12 am #15637327
Long Nguyen
Hi Ravi,
Thank you for contacting WPML support, I’m happy to help you with this issue.
As discussed in the chat session, it could be a feature request and I will share your feedback with the development team to consider supporting the feature to sync the empty ACF field value to the translation post. I will update you here when I have any information.
Meanwhile, you can add an empty space to the field value to sync it to the translation post.
Thanks for your patience.
