Last updated by Bruno 1 year ago.
May 14, 2019 at 10:52 pm #3810983
kristinaC-2
The English shop page is not displaying the English products that have been created. If you swap to the French version of the shop the french products show up correctly.
Here is an english product that should be displaying:
Periodically the shop will be able to load up with the english products displaying correctly but they will disapear after a refresh.
May 14, 2019 at 11:39 pm #3811031
Bruno
Thank you for contacting us. This looks like this page is not connected to WooCommerce.
In WooCommerce > Settings > Products, would you please confirm that the "Shop" page is selected? I'll attach an image for you to see.
May 15, 2019 at 3:43 pm #3818485
kristinaC-2
Yep the shop page is set within Woocommerce settings. If you inspect the page also you will see that the Woocomerce products wrapper is there it just has no products within it.
May 15, 2019 at 7:22 pm #3819859
Bruno
Thanks for checking this out. I'll need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help.
Note:
*** Please, can I install the Duplicator plugin (or All in One Migration) to make a copy of your site and install it on my test environment? This will help me debug the problem.
*** Note: Please make a full backup of your site.
Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
May 16, 2019 at 9:27 pm #3829463
Bruno
Thank you. I tried to create a copy of your site using Duplicator, but this did not work. It looks like the PHP ZipArchive extension is not enabled on your host.
Also, by analyzing your site a little more, I'm not sure if this is related to WPML. Since this works correctly in the secondary language, WPML by default should not influence the primary language.
Have you tried to disable all non-WPML plugins (keeping WooCommerce and WooCommerce Multilingual) to see if the problem persists?
May 16, 2019 at 10:43 pm #3829675
kristinaC-2
Ok so I have disabled all plugins other than WPML and Woocommerce and swapped to the default 2019 theme and am still seeing the same issue. No products displaying on the english store with the french working..
May 16, 2019 at 10:57 pm #3829813
Bruno
Now it looks like the products are being displayed correctly in both languages. I just saved the permalinks again (Settings> Permalinks).
Please, could you check?
May 17, 2019 at 4:14 pm #3835963
kristinaC-2
So it looks like the issue is partially fixed when permalinks are re-written. It looks like the bug is related to the Paid Member Subscription plugin from Cozmo Labs. (hidden link). With that plugin activated anytime you swap between the eng/fr versions of the shop the english products disappear. re-saving the permalinks brings them back but only until you swap the shop language again.
I have submitted a ticket with the plugin author also so hopefully they have an idea what would cause this..
May 17, 2019 at 6:40 pm #3836547
Bruno
This may be probably happening if the "Paid Member Subscription" plugin is regenerating the permalinks with each access.
Please let me know what the "Paid Member Subscription" plugin author says so I can check with our team too.
The topic ‘[Closed] English shop page is not displaying English products’ is closed to new replies.
