Last updated by krasimirD-2 10 months, 2 weeks ago.
July 17, 2019 at 9:32 am #4228229
krasimirD-2
I searched in the forum but I can't find any answers suitable for me with the languages per directories error.
July 17, 2019 at 11:10 am #4229265
Raja Mohammed
I will help you with your issue.
Could you please post the entire error message a screenshot would be of great help.
In some cases the error might be a false error (false positive) to confirm this we highly recommend Type the test call in your browser URL in the below format
When you make this call, you’ll get a blank looking page. Its content (which you can see by looking at the page’s source) should return your site URL in XML format eg: <!--hidden link;, If that is the case then you can ignore the warning message and continue using the directory URL for each language.
In most case, the error is related to the .htaccess file is not writable on your site also make sure the URL rewrite is enabled for your site.
Please refer https://wpml.org/documentation/getting-started-guide/language-setup/cannot-activate-language-directories/#make-sure-that-wordpress-enables-url-rewriting
please let me know if you need further assistance
Kind regards
Raja
July 17, 2019 at 12:29 pm #4230017
krasimirD-2
Hello, I upload 2 images with admin error, httacess file and the blank page witch not showing my url in XML format... I check the .httaccses file and it has the rewriting "function".
July 18, 2019 at 11:01 am #4237859
Raja Mohammed
Thanks for the information, Please share temporary access to your site, Let me check for a few parameters for more information about the issue. I have enabled private fields for you to securely share the details.
Kind regards
Raja
July 19, 2019 at 5:10 am #4243953
Raja Mohammed
Thanks for your access,
I have checked your site in detail. I can confirm that the directory URL for languages works fine without any issue, I am able to access the english shop page after allowing the user to view the hidden languages (screenshot attached).
Since the directory URL format works as expected you can ignore the warning notice, Some time the notice might be a false error which is similar in your case as well. I hope you can continue using directory URL format without any issues.
PS: In case if you are not aware of the fact that the hidden languages will be visible only to the user who has the access (Display hidden languages) enabled in their profile settings.
Please let me know if you need any further assistance.
Kind regards
Raja
July 22, 2019 at 6:15 am #4254137
krasimirD-2
