Last updated by Magnus 2 years, 6 months ago.
July 11, 2018 at 6:50 am #2485217
Magnus
Import AIT-settings (four languages) from an old website to one under development.
The documents and forum posts available under wpml.org.
According to previous forum posts on the issue of "Uncaught InvalidArgumentException: element_id and type do not match for element_id" it should've been solved in version 3.0, but we're running 4.0.4.
Please don't use the WPML Debug Info as we are unable to extract that information due to the bug.
July 11, 2018 at 5:31 pm #2487754
Bruno
Thank you for contacting us.
To resolve this issue you will need to remove those entries that are invalid. To do this, you must access your database and in the _icl_translations table, remove those records that are invalid.
For example, in the case of the error message that is in your screenshot, the element_id is 5127. You should search for it and remove it.
Remember before you follow the steps above, please make a full backup of your site.
If you want me to do it for you, just let me know so that I can request the credentials for you.
July 12, 2018 at 8:27 am #2488946
Magnus
Thank you kindly, this solved the issues for us.
