Our next available supporter will start replying to tickets in about 4.92 hours from now. Thank you for your understanding.
Last updated by gutti 4 years, 9 months ago.
Assigned support staff: Mladen Andrejic.
April 29, 2015 at 11:15 pm #609254
gutti
I am trying to: get my product categories (I only have one) to sync each other
URL of (my) website where problem appears: hidden link
I expected to see: Three products in the english category.
Instead, I got: but a 'No Results Found' message
May 4, 2015 at 6:58 am #610848
Mladen Andrejic
I think this is the problem with product-category base. Here is what you need to do :
1. Open Settings > Permalinks
2. Input "product-category" in "Product Category Base" under section "Optional" (I will provide you screenshot)
3. Hit Save changes
Screenshot : hidden link
// NOTE : Please use English for product-category base (this is a must). Also if you see that "product-category" is inputed but it's grey, then it's not inputed and you should do it yourself, this value should be black, just like in the screenshot.
And now :
1. Open WPML > Themes and plugins localization (Make sure option "Translate by WPML" is being used)
2. Under section "Strings in the plugins" check "WooCommerce" and "WooCommerce Multilingual" and hit "Scan the selected plugins for strings" button
3. Open WPML > String Translation
4. In search bar type in "product-category" and hit search button
5. You should now see the results (I will provide you another screenshot)
6. Translate each one of them to other languages (make sure you check "translation complete")
Now everything should work as expected.
May 8, 2015 at 9:59 am #614874
gutti
Thanks for the advice. I am in step 2 "Scan the selected plugins for strings". But this scan seems newer ending...it goes on and on and never stops....
May 8, 2015 at 10:04 am #614881
Mladen Andrejic
This can happen sometimes, if the scan takes longer than one minute, just refresh the page and try again, maybe you'll need to do it few times.
After you complete this step, continue following the procedure.
May 8, 2015 at 10:29 am #614909
gutti
Hi. I have tried to refresh several times - it just continues to scan.
May 8, 2015 at 10:41 am #614920
Mladen Andrejic
Can you please provide me the credentials to your website as I would like to take a closer look at this issue?
You will find the needed fields for this below the comment area when you log in to leave your next reply like this hidden link .
// NOTE : Make sure that you have performed the backup before you let me access the site.
May 8, 2015 at 12:23 pm #615044
Mladen Andrejic
I am sorry, but I am unable to access /wp-admin section with this account. Can you please provide me admin credentials?
I will mark next reply as private as well.
May 8, 2015 at 1:18 pm #615092
Mladen Andrejic
I saw in our String Translation Plugin that Product-Category base was already translated.
I have just inputed that base under Settings > Permalinks
Now everything works fine, please check hidden link and confirm that your issue is now resolved.
Have a nice weekend! 🙂
May 8, 2015 at 2:00 pm #615130
gutti
Hi Mladen. Yes, now everything works. Good job. Thanks and have a good weekend too 🙂
