Last updated by Puntorosso 2 years ago.
September 29, 2018 at 9:22 pm #2775805
Puntorosso
It would be nice if WMPL would have "Codes" fields in settings, where we could insert header/body/footer scripts like Google Analytics.
This fields should be available for any active language.
This way we could start a different script for any language that has been selected in front-end, and it's especially useful when we have a different domain/language.
I know that it's possible to achieve the same using if statements in php, but this would be a cleaner and comfortable way.
October 2, 2018 at 2:22 am #2779975
Bruno
Thank you for contacting and suggestion.
I can forward your ticket to our developers so they can check this out. At the moment, however, you can use the "Insert Headers and Footers" plugin (https://wordpress.org/plugins/insert-headers-and-footers/).
Then in WPML > Settings > Custom XML Configuration, insert these lines:
<wpml-config>
    <admin-texts>
        <key name="ihaf_insert_header" />
        <key name="ihaf_insert_footer" />
    </admin-texts>
</wpml-config>
By following these steps, you should be able to translate the content into WPML > String Translation. By following the steps above, this should work correctly.
Please, let me know if I can help with any other questions you may have. I'll be happy to help.
October 2, 2018 at 9:55 am #2780957
Puntorosso
Thanks for the tip.
Being a Toolset user I used another approach.
I created 2 custom fields in Types ("Header Script" and "Footer Script"), and inserted this code in functions.php
// insert Javascript Custom Field in header
function child_theme_head_script() {
echo (get_post_meta( get_the_ID(), 'wpcf-header-script', true));
add_action( 'wp_head', 'child_theme_head_script' );
// insert Javascript Custom Field in footer
function child_theme_foot_script() {
echo (get_post_meta( get_the_ID(), 'wpcf-footer-script', true ));
add_action( 'wp_footer', 'child_theme_foot_script' );
Now I simply translate this fields and it works.
As an additional advantage I can insert any script in a single post/page.
Best
