This topic contains 33 replies, has 2 voices.
Last updated by Laura 1 year, 5 months ago.
July 4, 2018 at 11:19 am #2462465
Laura
I can't download the file, I get a HTTP ERROR 409
July 4, 2018 at 7:17 pm #2464826
gabrielP-16
i try it its downloadable !
please check below :
please let me know if not works.
regards
July 5, 2018 at 7:59 am #2466040
Laura
I managed to download it with another browser, I'll let you know the results of my tests.
July 6, 2018 at 3:05 pm #2471215
Laura
I found that if you use as "display type" list instead of colour, the widget can be seen in both languages. Could you try and tell me if it does happen on your site too?
I understand it's not the solution you prefer, but if this is true it will be easier for our developers to find the problem.
July 6, 2018 at 4:12 pm #2471353
gabrielP-16
Hello Laura,
Yes if changing the Display Type its working fine,
but for colour Display type which my request ,its not working.
Gabriel
July 9, 2018 at 8:57 am #2475587
Laura
the issue has been escalated to compatibility team. I'll let you know as soon as I have news.
July 10, 2018 at 12:43 pm #2481219
gabrielP-16
Hello ,
Thanks for your Cooperation,
waiting for your positive reply.
Gabriel
July 11, 2018 at 1:24 pm #2486819
Laura
thanks for your patience. It might take sometimes as we have to prioritize issues, and in this case, there also is a workaround available for you so we might give precedence to compatibility issues that don't have a solution available yet.
July 26, 2018 at 7:33 am #2583082
Laura
our developers found a solution for this!
1. go to WPML -> Languages -> Make themes multilingual and check that the option is enabled
2. go to Appearance -> Editor:
- select theme to edit: Vitrine Child
- select theme files: functions.php
- go at the end of the file, where it says "write your codes in the following"
- below that line, add this code:
add_filter( 'option_widget_woocommerce_layered_nav', 'vitrine_translate_color_attributes' );
function vitrine_translate_color_attributes( $array ) {
	foreach ( $array as &$widget ) {
		if ( 'color' === $widget['display_type'] && ! empty( $widget['values'] ) ) {
			$values = array();
			foreach ( $widget['values'] as $slug => $value ) {
				$taxonomy = wc_attribute_taxonomy_name( $widget['attribute'] );
				$term = get_term_by( 'slug', $slug, $taxonomy );
				if ( ! empty( $term ) ) {
					$values[ $term->slug ] = $value;
			$widget['values'] = $values;
	return $array;
I tested it in my local copy of the site and it works for me. Let me know if this resolve the issue.
July 30, 2018 at 6:02 am #2592717
gabrielP-16
Hello Laura,
Thanks for your update,
i will check it within 2days and update you.
July 30, 2018 at 8:00 am #2592915
Laura
Ok, I'm waiting for your update then.
August 7, 2018 at 7:57 am #2618887
gabrielP-16
Hello Laura,
Sorry i have un expected issue i couldnt update the subject.
i will try to do it today or tomorrow,
thanks,
August 7, 2018 at 8:12 am #2618966
Laura
Hi Gabriel,
no problem, we will wait.
August 8, 2018 at 2:56 pm #2625352
gabrielP-16
Hello Laura,
Are you sure should be Child vitrin ?
if yes, i did it but not worked !
and if you mean the vitrin (main), i go to function file, there are where it says "write your codes in the following" to paste the code.
please advice.
August 8, 2018 at 3:02 pm #2625372
Laura
usually, child themes exist exactly because so you don't have to touch the code in the original theme. Otherwise everytime there is an update your custom code is overwritten.
Did you try to clear the cache and try again? I tried to check it myself but I get error 403 at hidden link
The topic ‘[Closed] FILTER (Woocommerce Products Filter)’ is closed to new replies.
