Last updated by Bobby 10 months ago.
Assigned support staff: Bobby.
July 5, 2019 at 12:25 pm #4151295
givt-sp.-z-o.o.J
CDN plugins like Google Cloud Storage are using filter upload_dir, which is replacing local urls to CDN based like hidden link.
In wmpl code you are using function wp_upload_dir() in files:
class-wpml-cache-directory.php
class-wpml-ls-model-build.php
class-wpml-flags.php
wpml-admin-lang-switcher.class.php
wp_upload_dir without parameters tries to create directory if it doesn't exist. What causes slow down of processing mostly in function filter_flag_url, because this directory cannot be created and it tries to create it over in over again. It also affect slow storage like S3.
In places when don't need to create directory (especially on page render) you should use everywhere wp_get_upload dir, or wp_upload_dir with second parameter set to false. After that change page rendering is 10 times faster.
July 6, 2019 at 1:46 am #4154237
Bobby
thank you for your suggestions , I will be updating our developers regarding this and will update you here once i have some news
July 8, 2019 at 5:53 pm #4164805
Bobby
if possible are you able to provide us with some additional data regarding the slow rending using your CDN and the difference afterwards ?
how are you currently measuring the speed of rendering ?
as we have not had such reports it is important to have as much information as possible so we can verify that this is not being caused by the CDN
July 9, 2019 at 7:40 am #4168205
givt-sp.-z-o.o.J
Rendering is caused not by CDN itself, but wp_mkdir_p() in wp_upload_dir() and the way you use wp_upload_dir();, because it every time tries to create directory. WP creators 3 years ago created even special parameter ($create_dir) to avoid such cases:
function wp_upload_dir( $time = null, $create_dir = true, $refresh_cache = false )
There is a discussion in their issue tracker why this parameter appeared, because directories should not be created on page rendering.
We are measuring rendering speed for example by:
curl -o /dev/null -s -w 'Total: %{time_total}s\n' hidden link etc
Of coourse on local machine
July 9, 2019 at 4:49 pm #4173243
Bobby
do you by any chance have any data that points to wp_upload_dir() function ? any screenshots of that data would be helpful
unfortunately i am not able to visit the link you provided above
July 16, 2019 at 3:26 pm #4221739
givt-sp.-z-o.o.J
What data do you mean? Place in code? Path to file that is tried to create?
With storage plugins there are paths like:
July 16, 2019 at 6:55 pm #4223397
Bobby
I have been in contact with our second tier regarding this and what they are asking for is some further data, any data that points to wp_upload_dir() function
we would like to know what points you to believe that it is wp_upload_dir() function causing the issue
you mentioned in the beginning of your ticket that changing it caused your rendering to speed up, how are you measuring your speed ? do you have any screenshots of the measurements before and after ?
if possible please provide us with any additional information you have pointing towards the wp_upload_dir() function
July 17, 2019 at 11:14 am #4229329
givt-sp.-z-o.o.J
OK.
I'm measuring rendering speed by example:
I know that it's reason because when I've replaced all ocurrences from wp_upload_dir() in WPML code to wp_get_upload() problem was solved.
Also I know why it's happening, because wp_upload_dir by default tries to create directory in filesystem, but when someone is using any CDN plugin links to upload files are not in filesystem but for example hidden link or hidden link.
Every time page is opened this function when it's running without parameters is trying to create directory, which cannot be created because it's not local.
Please forward all my messages to second tier, because everything is explained briefly there.
July 25, 2019 at 12:51 pm #4283273
givt-sp.-z-o.o.J
Any update on this?
July 25, 2019 at 10:03 pm #4286165
Bobby
our developers have been updated about this
I have been asked if you currently have a working example that you can provide us with access ?
We need to see how it was and how after the fixes.
i have enabled a private field reply for access to a working example
The topic ‘[Closed] filter_flag_url function causes massive slow down of site when using CDN.’ is closed to new replies.
