Last updated by przemyslawD-3 7 months, 3 weeks ago.
Assigned support staff: Bobby.
October 1, 2019 at 9:42 am #4670407
przemyslawD-3
I have an item on the page that I would like to display on only one language version (extendable slider with leasing offer - wpml1.jpg).
To show this link I put this code in the footer:
<script src="hidden link"></script>
In the other language versions I have translated this phrase into a comment (wpml2.jpg):
<!--Leaselink off-->
It works but only when I switch between languages. When I type the direct url of a specific language version, the slider still appears.
How can I fix it?
October 1, 2019 at 7:48 pm #4675125
Bobby
Hi There,
The quickest and most simple way to do this is to use a WPML constant that stores the current
language that the site is being viewed in.
It is called ICL_LANGUAGE_CODE and you can see a bit of documentation on it here: https://wpml.org/documentation/support/wpml-coding-api/
An example code would be:
<?php
if (ICL_LANGUAGE_CODE == "fr") {
    //show the form in French
} elseif (ICL_LANGUAGE_CODE == "de") {
    //show the form in German
} else {
    //show the default form in English if English is the default language
Please adjust the code with the correct language code and let me know your results, please.
October 3, 2019 at 10:33 am #4686837
przemyslawD-3
thanks for your response. I don't know, but the way I described also started working (maybe some catches were causing the problem?) 🙂
One more question about Your solution. What exactly It should look like in that case? Something like this? Or it isn't so easy (sorry, i don't know php very much).
<?php
if (ICL_LANGUAGE_CODE == "pl") {
    <script type="text/javascript" src="<em><u>hidden link</u></em>"></script>
} else {
October 3, 2019 at 4:18 pm #4689789
Bobby
Hi There,
the code looks good, there is no need for it to be more complicated 🙂
October 7, 2019 at 2:03 pm #4708193
przemyslawD-3
